18F25J50 configuration bits
fbtech
PostPosted: Wed Jun 03, 2015 6:30 am     Reply with quote
Hello, I'm using 18F25J50.
I configured my MCU fuses as follows:
#FUSES HS,NOCPUDIV,NOFCMEN,NOIESO,NOIOL1WAY,NOWDT,RTCOSC_INT,NOSTVREN,NOPROTECT,NODEBUG
I'm using MPLAB, when I use PICKIT3 as debugger my code is working fine and I get this message:
Resetting...
PK3Err0040: The target device is not ready for debugging.
Please check your configuration bit settings and program
the device before proceeding.
And when I use the PICKIT3 as programmer, I program the hardware and nothing is running.
I don't understand the problem.
PostPosted: Wed Jun 03, 2015 6:41 am     Reply with quote
hmm..
what's the last fuse you set ???
re: pgm doesn't run...
if you're using MPLAB be sure the 'build configuration' is set to 'release' and NOT 'debug'( the default)
Jay
fbtech
PostPosted: Wed Jun 03, 2015 6:57 am     Reply with quote
Thanks for your reply.
1- I use only these fuses
2- I configured the 'build configuration' to 'release' but I have the same problem ==> nothing is running Sad
PostPosted: Wed Jun 03, 2015 9:14 am     Reply with quote
So:
MCLR is pulled up?.
You have a crystal on RA6/RA7?.
With correct capacitors?.
GND on pin 8, & 19?.
Supply on Pin20?.
Decoupling capacitor close to the chip on the main supply, a separate one on the Vusb pin, _and a separate one on the Vddcore pin_ (very necessary)?.
You need NOXINST. You should have STVREN, not NOSTVREN.
What is your supply voltage?.
What is the crystal frequency?.
Does it start if you set FCMEN?. (would at least prove everything else is working other than the oscillator).
Compiler version?.
