madhura027
keypad program error: expecting declaration |
Posted: Wed May 27, 2015 4:49 am |
I am using mplab ide:
#include<16f877a.H>
#FUSES NOWDT,HS,NOPUT,PROTECT,NOBROWNOUT,NOLVP
#bit rs=0x06.1 //pin_b1 //RB1
#bit rw=0x06.2 //RB2
#bit en=0x06.3 //RB3
#byte data=0X08
#bit r1=0x07.0
#bit r2=0x07.1
#bit r3=0x07.2
#bit r4=0x07.3
#bit c1=0x07.4
#bit c2=0x07.5
#bit c3=0x07.6
#byte TRISB=0X86
#byte TRISC=0X87
#byte TRISD=0X88
int keypad(void);
void lcd_cmd(char value);
void ldata(char value);
int k,a;
TRISB=0x00;
TRISC=0xff;
TRISD=0x00;
output_low(rs); //rs=0
lcd_cmd(0x38);
lcd_cmd(0x0e);
lcd_cmd(0x01);
lcd_cmd(0x06);
lcd_cmd(0x80);
output_high(rs); // rs=1
keypad();
ldata(k);
delay_ms(1);
int keypad(void)
a=0;
do
r1=1;
r2=0;
r3=0;
r4=0;
if(c1==1)
k='1';
a=1;
if(c2==1)
k='2';
a=1;
if(c3==1)
k='3';
a=1;
r1=0;
r2=1;
r3=0;
r4=0;
if(c1==1)
k='4';
a=1;
if(c2==1)
k='5';
a=1;
if(c3==1)
k='6';
a=1;
r1=0;
r2=0;
r3=1;
r4=0;
if(c1==1)
k='7';
a=1;
if(c2==1)
k='8';
a=1;
if(c3==1)
k='9';
a=1;
r1=0;
r2=0;
r3=0;
r4=1;
if(c1==1)
k='0';
a=1;
if(c2==1)
k='*';
a=1;
if(c3==1)
k='#';
a=1;
while(!a);
return(k);
data=value;
rs=0;
rw=0;
en=1;
delay_ms(10);
en=0;
return;
data=value;
rs=1;
rw=0;
en=1;
delay_ms(10);
en=0;
return;
error:
Executing: "C:\Program files\Picc\CCSC.exe" +FM "keypad.c" +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 29 "keypad.c" Line 50(1,2): Function definition different from previous definition
*** Error 43 "keypad.c" Line 50(2,3): Expecting a declaration
*** Error 43 "keypad.c" Line 50(3,4): Expecting a declaration
*** Error 43 "keypad.c" Line 50(4,5): Expecting a declaration
*** Error 43 "keypad.c" Line 51(1,3): Expecting a declaration
*** Error 43 "keypad.c" Line 52(2,3): Expecting a declaration
*** Error 48 "keypad.c" Line 53(1,3): Expecting a (
*** Error 43 "keypad.c" Line 53(4,5): Expecting a declaration
*** Error 43 "keypad.c" Line 53(5,6): Expecting a declaration
*** Error 48 "keypad.c" Line 54(1,3): Expecting a (
*** Error 43 "keypad.c" Line 54(4,5): Expecting a declaration
*** Error 43 "keypad.c" Line 54(5,6): Expecting a declaration
*** Error 48 "keypad.c" Line 55(1,3): Expecting a (
*** Error 43 "keypad.c" Line 55(4,5): Expecting a declaration
*** Error 43 "keypad.c" Line 55(5,6): Expecting a declaration
*** Error 48 "keypad.c" Line 56(1,3): Expecting a (
*** Error 43 "keypad.c" Line 56(4,5): Expecting a declaration
*** Error 43 "keypad.c" Line 56(5,6): Expecting a declaration
*** Error 43 "keypad.c" Line 57(1,3): Expecting a declaration
*** Error 43 "keypad.c" Line 57(3,4): Expecting a declaration
*** Error 48 "keypad.c" Line 57(4,6): Expecting a (
*** Error 43 "keypad.c" Line 57(8,9): Expecting a declaration
*** Error 43 "keypad.c" Line 57(9,10): Expecting a declaration
*** Error 43 "keypad.c" Line 58(1,2): Expecting a declaration
*** Error 48 "keypad.c" Line 59(2,3): Expecting a (
*** Error 43 "keypad.c" Line 59(4,7): Expecting a declaration
*** Error 43 "keypad.c" Line 59(7,8): Expecting a declaration
*** Error 48 "keypad.c" Line 60(2,3): Expecting a (
*** Error 43 "keypad.c" Line 60(4,5): Expecting a declaration
*** Error 43 "keypad.c" Line 60(5,6): Expecting a declaration
*** Error 43 "keypad.c" Line 61(1,2): Expecting a declaration
*** Error 43 "keypad.c" Line 62(1,3): Expecting a declaration
*** Error 43 "keypad.c" Line 62(3,4): Expecting a declaration
*** Error 48 "keypad.c" Line 62(4,6): Expecting a (
*** Error 43 "keypad.c" Line 62(8,9): Expecting a declaration
*** Error 43 "keypad.c" Line 62(9,10): Expecting a declaration
*** Error 43 "keypad.c" Line 63(1,2): Expecting a declaration
*** Error 48 "keypad.c" Line 64(2,3): Expecting a (
*** Error 43 "keypad.c" Line 64(4,7): Expecting a declaration
*** Error 43 "keypad.c" Line 64(7,8): Expecting a declaration
*** Error 48 "keypad.c" Line 65(2,3): Expecting a (
*** Error 43 "keypad.c" Line 65(4,5): Expecting a declaration
*** Error 43 "keypad.c" Line 65(5,6): Expecting a declaration
*** Error 43 "keypad.c" Line 66(1,2): Expecting a declaration
*** Error 43 "keypad.c" Line 67(1,3): Expecting a declaration
*** Error 43 "keypad.c" Line 67(3,4): Expecting a declaration
*** Error 48 "keypad.c" Line 67(4,6): Expecting a (
*** Error 43 "keypad.c" Line 67(8,9): Expecting a declaration
*** Error 43 "keypad.c" Line 67(9,10): Expecting a declaration
*** Error 43 "keypad.c" Line 68(1,2): Expecting a declaration
*** Error 48 "keypad.c" Line 69(2,3): Expecting a (
*** Error 43 "keypad.c" Line 69(4,7): Expecting a declaration
*** Error 43 "keypad.c" Line 69(7,8): Expecting a declaration
*** Error 48 "keypad.c" Line 70(2,3): Expecting a (
*** Error 43 "keypad.c" Line 70(4,5): Expecting a declaration
*** Error 43 "keypad.c" Line 70(5,6): Expecting a declaration
*** Error 43 "keypad.c" Line 71(1,2): Expecting a declaration
*** Error 48 "keypad.c" Line 72(1,3): Expecting a (
*** Error 43 "keypad.c" Line 72(4,5): Expecting a declaration
*** Error 43 "keypad.c" Line 72(5,6): Expecting a declaration
*** Error 48 "keypad.c" Line 73(1,3): Expecting a (
*** Error 43 "keypad.c" Line 73(4,5): Expecting a declaration
*** Error 43 "keypad.c" Line 73(5,6): Expecting a declaration
*** Error 48 "keypad.c" Line 74(1,3): Expecting a (
*** Error 43 "keypad.c" Line 74(4,5): Expecting a declaration
*** Error 43 "keypad.c" Line 74(5,6): Expecting a declaration
*** Error 48 "keypad.c" Line 75(1,3): Expecting a (
*** Error 43 "keypad.c" Line 75(4,5): Expecting a declaration
*** Error 43 "keypad.c" Line 75(5,6): Expecting a declaration
*** Error 43 "keypad.c" Line 76(1,3): Expecting a declaration
*** Error 43 "keypad.c" Line 76(3,4): Expecting a declaration
*** Error 48 "keypad.c" Line 76(4,6): Expecting a (
*** Error 43 "keypad.c" Line 76(8,9): Expecting a declaration
*** Error 43 "keypad.c" Line 76(9,10): Expecting a declaration
*** Error 43 "keypad.c" Line 77(1,2): Expecting a declaration
*** Error 48 "keypad.c" Line 78(2,3): Expecting a (
*** Error 43 "keypad.c" Line 78(4,7): Expecting a declaration
*** Error 43 "keypad.c" Line 78(7,8): Expecting a declaration
*** Error 48 "keypad.c" Line 79(2,3): Expecting a (
*** Error 43 "keypad.c" Line 79(4,5): Expecting a declaration
*** Error 43 "keypad.c" Line 79(5,6): Expecting a declaration
*** Error 43 "keypad.c" Line 80(1,2): Expecting a declaration
*** Error 43 "keypad.c" Line 81(1,3): Expecting a declaration
*** Error 43 "keypad.c" Line 81(3,4): Expecting a declaration
*** Error 48 "keypad.c" Line 81(4,6): Expecting a (
*** Error 43 "keypad.c" Line 81(8,9): Expecting a declaration
*** Error 43 "keypad.c" Line 81(9,10): Expecting a declaration
*** Error 43 "keypad.c" Line 82(1,2): Expecting a declaration
*** Error 48 "keypad.c" Line 83(2,3): Expecting a (
*** Error 43 "keypad.c" Line 83(4,7): Expecting a declaration
*** Error 43 "keypad.c" Line 83(7,8): Expecting a declaration
*** Error 48 "keypad.c" Line 84(2,3): Expecting a (
*** Error 43 "keypad.c" Line 84(4,5): Expecting a declaration
*** Error 43 "keypad.c" Line 84(5,6): Expecting a declaration
*** Error 43 "keypad.c" Line 85(1,2): Expecting a declaration
*** Error 43 "keypad.c" Line 86(1,3): Expecting a declaration
*** Error 43 "keypad.c" Line 86(3,4): Expecting a declaration
*** Error 48 "keypad.c" Line 86(4,6): Expecting a (
*** Error 43 "keypad.c" Line 86(8,9): Expecting a declaration
*** Error 43 "keypad.c" Line 86(9,10): Expecting a declaration
100 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED |
