Pic24FJ16MC102 Motor PWM function problem
pieter
PostPosted: Fri Apr 24, 2015 3:26 am     Reply with quote
Hi Guys,
I have a Pic24FJ16MC102 pcb that runs well except I can not get the MOTOR PWM function to work. I use H and L of PWM pair set no 1.
I have tried all logical combinations of:
#FUSES NOPWMLOCK
#FUSES PWMPIN  // tried with and without
setup_motor_pwm(1,MPWM_FREE_RUN,4,0,0x7FFF); // tried various options
set_motor_unit(1,1,MPWM_ENABLE | MPWM_FAULT_NO_CHANGE,100,100);
set_motor_pwm_duty(1,1,0x7FFF);     //Set pin pair 1 to a 50% duty cycle.
Toggling the pins with i/o commands work but with the above PWM functions, all is quiet.
Am I overlooking something?
Thanks for help.
PostPosted: Fri Apr 24, 2015 6:14 pm     Reply with quote
Since no one else has answered, I will try to help (I don't have the PCD compiler).
Here is an example from Eduardo. It's for the dsPIC30, but it's similar
and may work with your PIC.
Example using motor PWM with dsPIC30F2010:
http://www.ccsinfo.com/forum/viewtopic.php?t=51642
pieter
PostPosted: Sat Apr 25, 2015 11:46 am     Reply with quote
Thank you, I have just about tested every option including from the example to mention. It does not work.
I had to revert back to simple PWM functioning.
However, to get it going on this chip, here are the required fuse settings:
#FUSES NOPWMLOCK                  //PWM Change Unlocked
#FUSES NOPWMPIN                    // Define PWM pin after reset
#pin_select OC1= Pin_B14          // Assign functions to pins
#pin_select OC2= Pin_B15
Setup_Timer2(Tmr_Internal | Tmr_div_by_256, 288);
Setup_Compare(1,COMPARE_PWM | COMPARE_TIMER2);
SET_PWM_DUTY(1,144);   // 50% dc
Setup_Compare(2,COMPARE_PWM | COMPARE_TIMER2);
SET_PWM_DUTY(2,72);   // 25% dc
