Keyboard Menu
ad
Keyboard Menu
PostPosted: Fri Apr 17, 2015 2:01 am     Reply with quote
I want a menu that touching a keyboard key data is obtained. It would be as follows:
Select: 1. Obtain 2. Transmit
If you select one, another menu with 4 options ( 1.Temp 2.NCOMB 3.RPM 4.VEL ) appears.
If you select two would have to appear on screen transmitting data.
In the submenu of the parameters would also have to have an option to turn back.
Here I leave the code I've tried to do.
void main(){
   //Variable de las funciones de parametros
   char k;
   int x;
   lcd_init();
   kbd_init();
   port_b_pullups(TRUE);
   //Mensaje de Inicio
   lcd_gotoxy(4,1);
   printf(lcd_putc, "BIENVENIDOS");
   lcd_gotoxy(7,2);
   printf(lcd_putc, "FLIPS");
   delay_ms(300);
   lcd_putc('\f');
   lcd_gotoxy(4,1);
   printf(lcd_putc, "MARTES 10");
   lcd_gotoxy(4,2);
   printf(lcd_putc, "MAYO 2015");
   delay_ms(300);
   lcd_putc('\f');
   lcd_gotoxy(1,1);
   printf(lcd_putc, "REALIZADO POR:");
   lcd_gotoxy(1,2);
   printf(lcd_putc, "xxx");
   delay_ms(300);
   lcd_putc('\f');
   lcd_gotoxy(1,1);
   printf(lcd_putc, "SELECCIONE:");
   lcd_gotoxy(1,2);
   printf(lcd_putc,"1.OBT 2.TRANS");
      while(1){              //Bucle infinito siempre consulta el teclado
      k=kbd_getc(); //leer el teclado
      x=k-48;       //Conversion numerica
      switch(k){
      case 1:
         lcd_gotoxy(1,1);
         printf(lcd_putc, "1.TEMP 2.NCOMB");
         lcd_gotoxy(1,2);
         printf(lcd_putc, "3.RPM 4.VEL");
         delay_ms(300);
         lcd_putc('\f');
         switch (k){
            case 1:
               lcd_gotoxy(1,1);
               printf(lcd_putc,"OBT.DATOS...");
               NTC();
            case 2:
               lcd_gotoxy(1,1);
               NIVEL_COMBUSTIBLE();
            case 3:
               lcd_gotoxy(1,1);
               REVOLUCIONES();
            case 4:
               lcd_gotoxy(1,1);
               VELOCIDAD();
            case 5:
               lcd_gotoxy(1,1);
               printf(lcd_putc,"MENU PRINCIPAL");
    case 2:
      lcd_gotoxy(1,1);
      printf(lcd_putc,"TRANS.DATOS...");
