How to distinguish a reset_cpu() and a power up restart
Ivar Boer
PostPosted: Tue Feb 18, 2003 6:39 am     Reply with quote
Hello programmers,
Iam using a PIC16F877A processor.
I have implemented the function reset_cpu(). This function is translated in assmble code goto 0x000. After this function I want to do a restart cause check with the function restart_cause(). If both bits (!TO) and (!PD) are 1 a power up occured.
When a power up occured my Time Counters have to be set to 0, otherwise not.
Now the problem is that the restart_cause() function always sees a power up (I think this status of the last power up), which means the reset_cpu() function does not infect bits (!TO) and (!PD).
Can someone help to distinguish these types of restarts from eachother in a nice way.
Thanks!
___________________________
Original Post ID: 11824
Tomi
Re: How to distinguish a reset_cpu() and a power up restart
PostPosted: Tue Feb 18, 2003 7:15 am     Reply with quote
I use the PowerOn bit which is cleared only if the PIC is powered on. You must set this bit by software after reset (see Chapter 2.2.2.8 for details):
#byte PCON = 0x8E
if (!bit_test(PCON,1)) {
DoPowerUp(); // what to do in case of power-up
bit_set(PCON,1);
Then I implement a "full-restart" as:
bit_clear(PCON,1); // force PIC to execute power-up function
while (1) ; // watchdog does the job
:=Hello programmers,
:=Iam using a PIC16F877A processor.
:=I have implemented the function reset_cpu(). This function is translated in assmble code goto 0x000. After this function I want to do a restart cause check with the function restart_cause(). If both bits (!TO) and (!PD) are 1 a power up occured.
:=When a power up occured my Time Counters have to be set to 0, otherwise not.
:=Now the problem is that the restart_cause() function always sees a power up (I think this status of the last power up), which means the reset_cpu() function does not infect bits (!TO) and (!PD).
:=Can someone help to distinguish these types of restarts from eachother in a nice way.
:=Thanks!
Original Post ID: 11827
