Split string from serial data(RS232)?
kodomo32
PostPosted: Tue Apr 07, 2015 12:23 pm     Reply with quote
Hello
I'm new for programing , I want check data from serial port PC to PIC
my condition
1. PC set data to PIC => load cell value 125 kg. in "WV000125" format
2.PIC check data if "WV" print data "000125"
can you help me, please
my code.
#include <16f628A.h>
#fuses NOWDT,HS, NOPUT, NOPROTECT,NOLVP,BROWNOUT
//#use delay (clock=12000000)
#include <string.h>
#use delay (clock=18432000)
#use rs232(baud=19200,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8)
   char string[30];
   char name[30];
   strcpy(name, "WV");
      gets(string);
      if(strcmp(string, name))
       ' get string to array
PostPosted: Tue Apr 07, 2015 12:33 pm     Reply with quote
Strcmp() doesn't return TRUE if there is a match. It returns 0.
Always read the function description.
PostPosted: Tue Apr 07, 2015 4:04 pm     Reply with quote
add the ERRORS argument to your #use rs232 declaration.
also GETS() is a high risk call since there is no way in your program to break out of the while loop if no CARRIAGE return is received or if transmission stops for any other reason.
You are assuming that everything will happen "just so"as you imagine in your program -- when in fact the real world may intrude and hang it -- Very Happy Very Happy Very Happy
Mike Walne
PostPosted: Wed Apr 08, 2015 7:46 am     Reply with quote
CCS provides sample code (eg EX_STR.C) for handling string functions and RS232.
Mike
kodomo32
PostPosted: Wed Apr 08, 2015 11:40 am     Reply with quote
Thanks for many advise, Now i can check data from serial port
but code is long, is there anyway to write to short form.
char a[7],char C;
int i2,i3;
C=getc();
if(C=='W') {   // Check data 'W"
      a[0]=C;
      C=getc();
      if (C=='V'){// Check data 'V'
      a[1]=C;
      C=getc();
      a[2]=C;
      C=getc();
       a[3]=C;
      C=getc();
      a[4]=C;
      C=getc();
      a[5]=C;
       C=getc();
      a[6]=C;
      C=getc();
      a[7]=C; }
    else {   // clear data
          for (i2=0;i2<=7;++i2)
                  a[i2]="";
   else { //clear data
               a[i2]="";
     for (i3=2;i3<=7;++i3)
           printf ("%c",a[i3]);// Print "000125"
PostPosted: Wed Apr 08, 2015 12:26 pm     Reply with quote
This look a lot more complex, but is doing a lot more...
const char lookfor[]="WV";
#define ISNUM(x) (x>='0' && x<='9')
int1 look(void)
   char numbers[7], tempchr;
   int state=0;
   do
      tempchr=getc();
      switch (state)
      case 0:
      case 1:
        if (tempchr==lookfor[state])
           state++
           return FALSE; //failed not WV
      case 2:
      case 3:
      case 4:
      case 5:
      case 6:
         if (ISNUM(tempchr))
            numbers[state-2]=tempchr;
            state++;
            return FALSE; //not a number
      case 7:
         if (ISNUM(tempchr))
            numbers[state-1]='\0'; //null terminate the number
            printf("%s",numbers); //print the numbers
            return TRUE;
This looks for the "WV", and returns 'FALSE' if this is not found, or if the 'digits' arriving afterwards are not digits. Returns TRUE if it all works.
However several things it does could be used to simplify your version if you didn't want to go so far. For instance, printing the numbers as a string by just adding the terminator, just searching for the text from a string, rather than character by character etc..
