artohautala
why my parameters to function don't work ? |
Posted: Fri Mar 20, 2015 5:31 am |
why this don't work:
old_value = 1357;
value = 0;
if(value != old_value){
//split_number(old_value); //digits to global variables g_thous, g_hunds, g_tens and g_ones;
//old_thous = g_thous; old_hunds = g_hunds; old_tens = g_tens; old_ones = g_ones;
//split_number(value); //digits to global variables g_thous, g_hunds, g_tens and g_ones
update_digits(old_value,value,ref_value );
graph_indicator (meter_gain,value,old_value,old_meter_gain);
//calculate distortion percent
but this work fine:
void update_digits(int16 old_value, int16 ref_value, int16 value) {
int8 old_thous, old_hunds, old_tens, old_ones;
//old_value = 0; this is ok
//value = 1234; this is ok
if( g_thous != old_thous){
//write old_thous in backround colour to clean it
putc(0x53); //cmd write ASCII text string graphics format, page 44
putc(0); //top left x MSB
putc(10); //top left x LSB
putc(0); //top left y MSB
putc(120); //top left y LSB
putc(3); //font 3 = 12 x 16
putc(0xC6); //string colour backcolour
putc(0x18); //string colour backcolour
putc(0x02); //widht multiplier = 2
putc(0x02); //height multiplier = 2
printf("%u",old_thous);
putc(0x00); //string terminator
com_ok();
//write g_thous in black colour to show it
putc(0x00); //string colour black
printf("%u",g_thous);
com_ok();
if( g_hunds != old_hunds){
//write old_hunds in backround colour to clean it
putc(34); //top left x LSB
printf("%u",old_hunds);
com_ok();
//write hunds in black colour to show it
printf("%u",g_hunds);
com_ok();
if( g_tens != old_tens){
//write old_tens in backround colour to clean it
putc(58); //top left x LSB
printf("%u",old_tens);
com_ok();
//write tens in black colour to show it
putc(0x02); //widht multiplier = 3
putc(0x02); //height multiplier = 3
printf("%u",g_tens);
com_ok();
if( g_ones != old_ones){
//write old_ones in backround colour to clean it
putc(82); //top left x LSB
printf("%u",old_ones);
com_ok();
//write ones in black colour to show it
printf("%u",g_ones);
com_ok();
//print 100.0 %
putc(80); //top left y LSB
printf("%s","100.0 %");
com_ok();
//program stop here:
e:;goto e;
all the variables are int16...
my display show 0000 it should be here 1357
I'm very sure my program really goes to
because I changed that printf("%s","100.0 %");
to 110.0% ...
I'm very confused about this simple problem ...
friendly regards
-arto hautala- |
asmboy
Posted: Fri Mar 20, 2015 6:40 am |
you beat me. i can't tell for the life of me WHAT does not wrok.
ps : learn to use the CODE button Code: |
old_value = 1357;
value = 0;
but this work fine:
com_ok();
com_ok();
com_ok();
com_ok();
com_ok();
com_ok();
com_ok();
com_ok();
//print 100.0 %
com_ok();
artohautala
Posted: Fri Mar 20, 2015 6:49 am |
Sorry ,javascript:emoticon(' ')
asmboy
I forgot to use CODE button...
this is also wrong I tried all kind of everything... and I forgot to change it ...
old_value = 1357;
value = 0;
should be :
old_value = 0;
value = 1357;
all the best
-arto-
![Embarassed](images/smiles/icon_redface.gif) |
artohautala
here is my whole code |
Posted: Fri Mar 20, 2015 7:23 am |
/* TÄSSÄ VERSIOSSA OTETAAN KÄYTTÖÖN SÄRÖMITTARI MAHDOLLISUUS ERILLISELLÄ TASOMITTARIN
INPUT BNC-LIITTIMELLÄ
/*/CHECK LIST:
TARKISTA KAIKKI "TESTIT" !
11. tee lopullinen offset hienosäätö lopullisella virtalähteellä, katso word ohje "offset_ohje" !
16. dig arvot muistiin / muistista
18. EI OSAA HAKEA MUISTISTA JOS SÄHKÖT KAUAN POIS PÄÄLTÄ ???????????????????
20. TARKISTA ERI FUNKTIOIDEN EEPROM OSOITEALUE
21. pickit2 tuhoaa eeprommin jos et valitse oikein !
22. jos haluaa hienostella niin vain punaiset tekstit ovat klikattavissa
23. muuta harmaaksi jos ei klikattavissa MUUTEN PUNAINEN !
24. graph_indicator vähän tyhmästi tekee kaIKELAISTA vaikka tilanne ei ole muuttunut !
#include<18F4525.h>
//reset_cpu();
#device ADC=10 //10 bits a/d converter
#ORG DEFAULT
#include<stdio.h>
#include <string.h>
#include <stdlib.h>
#use rs232(FORCE_SW,baud=9600,xmit=pin_c6,rcv=pin_c7,stream=LCD)
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT
//select D-PORT for extra I/O pins in analog generator, active LOW:
#define ext_d_port (PIN_C0)
#define LCD_reset (PIN_C1) //reset LCD display module, active LOW
#define rel_20dB (PIN_C2) //FUNCTION GENERATOR -20dB attenuator relay
#define pot_cs (PIN_C3) //digital potentiometer chip select, active LOW
#define pot_up_down (PIN_C4) //digital potentiometer up/down, LOW = DOWN
#define pot_inc (PIN_C5) //digital potentiometer incremental
/*C0 extra I/O pin must be low (74244 buffer selected), B5 high (D/A converter chip not selected)
when using D-port pins !*/
#define on_off_rel (PIN_D0) //signal on/off relay, 6s delay at startup
#define rel_40dB (PIN_D1) //FUNKTION GENERATOR -40dB attenuator relay
#define distm_onoff (PIN_D2) //särömittari on-off
#define distm_gain_1 (PIN_D3) //+20 dB vahvistyspyyntö tasomittarille särömittarilta
#define distm_gain_2 (PIN_D4) //gain1 + gain2 +40 dB vahv.pyyntö tasomit. särömittarilta
#define att_gain_1 (PIN_D5) //+20 dB vahvistyspyyntö tasomittarille vaimentimelta
#define att_gain_2 (PIN_D6) //gain1 + gain2 +40 dB vahv.pyyntö tasomit.vaimentimelta
//PIN_D7 DIGITAL PULSE OUT
#define level_AD (PIN_A0) //level meter A/D input
#define rel_200Hz (PIN_A1) //200Hz relay and 200Hz sin. filter
#define rel_2kHz (PIN_A2) //2kHz relay and 2kHz sin. filter
#define rel_20kHz (PIN_A3) //20kHz relay and 20kHz sin. filter
// (PIN_A4) is for freq: counter input !!
#define rel_20Hz (PIN_A5) //20Hz relay and 20 Hz sin. filter
#define triangle_rel (PIN_E0) //triangle wave ON state, otherwise sin (XR2206 board)
#define square_rel (PIN_E1) //square wave if ON (XR2206 board)
#define sine_rel (PIN_E2) //skip sinewave filter when using triangle or square wave
#define DA_wr (PIN_B4) //D/A converter write,active LOW
#define DA_cs (PIN_B5) //D/A converter chip select,active LOW
#define sine 1 //for sel_wavemode function
#define triangle 2 //for sel_wavemode function
#define square 3 //for sel_wavemode function
#define Hz20 1 //for freq_area function
#define Hz200 2 //for freq_area function
#define Hz2k 3 //for freq_area function
#define Hz20k 4 //for freq_area function
#define NoTouchActivity 0 //for LCD get touch coordinates
#define TouchPress 1 //for LCD get touch coordinates
#define TouchRelease 2 //for LCD get touch coordinates
#define TouchMoving 3 //for LCD get touch coordinates
#define GetTouchStatus 4 //for LCD get touch coordinates
#define GetTouchCoordinates 5 //for LCD get touch coordinates
#define analog 1
#define digital 2
#define distortion 3
#define u_ramp 6 //these are for digital function select
#define d_ramp 7
#define up_down 8
#define pulses 9
#define bursts 10
#define BACK 11
#byte PORTB = 0xF81 //port A = 0xF80 and so on...
#byte PORTD = 0xF83
void start_init(void);
//color LCD functions:
void com_ok(void);
int8 screen_1(void);
void autobaud(void);
void display_on(void);
void display_off(void);
void backlight_off(void);
void backlight_on(void);
void backlight_colour(int16 bck_colour); //look color picker !
void draw_button(short int state,int16 x_TOP_LEFT,int16 y_TOP_LEFT,int16 colour,
int8 size,int16 text_colour, char text[]);
void en_touch_screen(void);
void touch_region(int16 x1,int16 x2,int16 y1,int16 y2);
void analog_gen(void);
void wr_range(int8 range);
void wr_divider(int8 divider);
void an_buttons(void); //draw analog buttons
void redraw_mode(int8 mode);
void wr_offset(float offset_v);
void sel_wavemode(int8 wave); //select sine, triangle or square wave mode
void freq_area(int8 freq_area); /*freq. area and corresponding filter selected:
1...4: 20Hz,200Hz,2kHz and 20 kHz*/
void atten_rel(int8 atten); //signal attenuation 0, -20, -40 dB
void relays_off(void); //all relays softly OFF
void show_freq_level(int8 wave_mode,int8 divider,int1 show_freq);
//wave_mode 1 = sine, 2 = triangle 3 = square
void ret_offset_RESET(void); //returns offset to 0 V after reset or return
void dist_screen(int1 ref_level); // distortion meter screen
void dist_meter(void);
int8 GetTouch(int8 mode); //mode is often 0x04, get touch status page 47 manual
void anadisp_init(int1 show_freq);
void wait_delay(void);
void range_wait(void);
void graph_indicator (int8 meter_gain, int16 value, int16 old_value,int8 old_meter_gain );
void draw_balks(void);
void update_digits(int16 old_value, int16 ref_value, int16 value);
//DIGITAL FUNCTIONS:
int1 digi_gen(void); //select digital generator
int8 ask_waveform(void); //ask digital function
int1 set_risetime(void); //set risetime and call run_upramp
void run_upramp(int16 risetime); // up ramp is running now
int1 set_falltime(void); //set falltime and call run_downramp
void run_downramp(int16 falltime); //down ramp is running now
void draw_number(int8 number,int8 x,int8 y);
void clear_ramp_digit(int8 digit);
void show_eememory(int8 wave);
int1 set_rise_falltimes(void); //set triangle wave rise and falltimes
void run_up_dwnramp(int16 risetime,int16 falltime); //triangle wave
void split_number(int16 value);
int1 set_dig_pulses(void);
void run_pulses(int16 on_time,int16 off_time,int1 on_us, int1 off_us); //digital pulses
//global identifiers:
int8 g_ints;
int1 g_high_freq, Gcancel;
static int1 G_START;
static signed int8 g_offset_wiper ; //value -127... +128 !
int16 G_xplace,G_yplace; //touch coordinates x and y
int8 g_thous, g_hunds, g_tens, g_ones; // thousands, hundreds, tens and ones
void main(void){
int8 mode;
int1 i;
g_thous = g_hunds = g_tens = g_ones = 0;
G_START = TRUE;
start_init();
ret_offset_RESET();
i = TRUE;
while(i){
mode = screen_1();
if(mode == analog)
analog_gen();
if(mode == digital)
digi_gen();
if(mode == distortion)
dist_meter();
int1 digi_gen(void){
int8 waveform;
//DA chip AD7545 is 12 bits LSB D0...D7 MSB B0...B3,
output_high(ext_d_port); //analog generator use D_port for I/O ! HIGH not sel.
set_tris_b(0B11110000); //B-port bits 0...3 outputs
set_tris_d(0B00000000); //D-port all bits outputs
output_low(DA_cs); //select DA-converter
delay_ms(1);
output_low(DA_wr); // wr to DA-converter
delay_ms(1);
// first init gard:
putc(0x40); putc(0x69);com_ok();
//set to old format (default):
putc(0x59); putc(0x06);putc(0x00);com_ok();
waveform = ask_waveform();
if(waveform == FALSE)
return FALSE;
if(waveform == u_ramp){
if(set_risetime() == FALSE)
return FALSE;
if(waveform == d_ramp){
if( set_falltime()== FALSE)
return FALSE;
if(waveform == up_down){
if(set_rise_falltimes() == FALSE)
return FALSE;
if(waveform == pulses){
if(set_dig_pulses() == FALSE)
return FALSE;
//this loads up going ramp from memory picture from sd-card:
void ur1(void){
/*Picaso Data:
0x40, 0x6D, "func_gen.Gci", 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x7E, 0x00
putc(0x40);putc(0x6D);
printf ("func_gen.Gci");
putc(0x00);putc(0x00);putc(0x00);putc(0x00);putc(0x00);putc(0x00);
putc(0x3F);putc(0x7E);putc(0x00);
com_ok();
//this loads up going ramp INFORMATION picture from sd-card:
void ur2(void){
/*Picaso Data:
0x40, 0x6D, "func_gen.Gci", 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x41, 0xD8, 0x00
putc(0x41);putc(0xD8);putc(0x00);
com_ok();
void ur3(void){
//this loads set up rise time of up going ramp picture from sd-card:
/*Picaso Data:
0x40, 0x6D, "func_gen.Gci", 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x44, 0x32, 0x00
putc(0x44);putc(0x32);putc (0x00);
com_ok();
void ur4(void){
//this loads save rise time of up going ramp picture from sd-card:
/*Picaso Data:
0x40, 0x6D, "func_gen.Gci", 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x46, 0x8C, 0x00
putc(0x46);putc(0x8C);putc (0x00);
com_ok();
//this loads down going ramp from memory picture from sd-card:
void dr5(void){
/*Picaso Data:
putc(0x17);putc(0x84);putc(0x00);
com_ok();
//this loads down going information picture from sd-card:
void dr6(void){
/*Picaso Data:
0x40, 0x6D, "func_gen.Gci", 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x19, 0xDE, 0x00
putc(0x19);putc(0xDE);putc(0x00);
com_ok();
void dr7(void){
/*Picaso Data:
putc(0x1C);putc(0x38);putc(0x00);
com_ok();
//this loads to memory down going ramp picture from sd-card:
void dr8(void){
/*Picaso Data:
0x40, 0x6D, "func_gen.Gci", 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x92, 0x00
putc(0x1E);putc(0x92);putc(0x00);
com_ok();
//this loads triangle picture from sd-card:
void tr9(void){
/*Picaso Data:
0x40, 0x6D, "func_gen.Gci", 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x36, 0x16, 0x00
putc(0x36);putc(0x16);putc(0x00);
com_ok();
//this loads triangle INFORMATION picture from sd-card:
void tr10(void){
/*Picaso Data:
0x40, 0x6D, "func_gen.Gci", 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x70, 0x00
putc(0x38);putc(0x70);putc(0x00);
com_ok();
//this loads triangle picture risetime / falltime from sd-card:
void tr11(void){
/*Picaso Data:
0x40, 0x6D, "func_gen.Gci", 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3A, 0xCA, 0x00
putc(0x3A);putc(0xCA);putc(0x00);
com_ok();
//this loads pulses INFORMATION picture from sd-card:
void pu14(void){
/*Picaso Data:
0x40, 0x6D, "func_gen.Gci", 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x25, 0xA0, 0x00
putc(0x25);putc(0xA0);putc(0x00);
com_ok();
//this loads pulses new value picture from sd-card:
void pu15(void){
/*Picaso Data:
0x40, 0x6D, "func_gen.Gci", 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x27, 0xFA, 0x00
putc(0x27);putc(0xFA);putc(0x00);
com_ok();
int8 ask_waveform(void){
/*/first load screen from SD-card that ask waveform:
the data below is from SGS graphics controller:*/
/*Picaso Data:
0x40, 0x6D, "func_gen.Gci", 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x33, 0xBC, 0x00
putc(0x33);putc(0xBC);putc(0x00);
com_ok();
//destroy burst it is not used
putc(0x72);putc(0); putc(110);putc(0);putc(154);putc(0); putc(210);putc(0); putc(224);
putc(0xAE);putc(0xDC);
com_ok();
/* up_ramp button x1 = 6, x2 = 105, y1 = 80, y2 = 150
d_ramp button x1 = 110, x2 = 210, y1 = 80, y2 = 150
triangle button x1 = 215, x2 = 314, y1 = 80, y2 = 150
pulses button x1 = 6, x2 = 105, y1 = 155, y2 = 224
bursts button x1 = 110, x2 = 210, y1 = 155, y2 = 224
BACK button x1 = 215, x2 = 314, y1 = 155, y2 = 224
en_touch_screen();
touch_region(0,319,0,239); //detect touch region, whole display
while(TRUE){
//wait until touch press forever
do{
}while(GetTouch(GetTouchStatus) != Touchpress);
GetTouch(GetTouchCoordinates); //coordinates for buttons
//up going ramp button pressed:
if((G_xplace > 6) && (G_xplace < 105) && (G_yplace > 80) && (G_yplace < 150)){
putc(0x45); com_ok(); //clear screen
return u_ramp;
//down going ramp button pressed:
if((G_xplace > 110) && (G_xplace < 210) && (G_yplace > 80) && (G_yplace < 150)){
return d_ramp;
//triangle wave button pressed:
if((G_xplace > 215) && (G_xplace < 314) && (G_yplace > 80) && (G_yplace < 150)){
return up_down;
//pulses button pressed:
if((G_xplace >6) && (G_xplace < 105) && (G_yplace > 155) && (G_yplace < 224)){
return pulses;
//Gcancel button pressed:
if((G_xplace >215) && (G_xplace < 314) && (G_yplace > 155) && (G_yplace < 224)){
return FALSE;
int8 GetTouch(int8 mode){ /*mode = 4 or 5, get touch status or get touch coordinates,
page 47 manual*/
int8 x_coord_MSB,x_coord_LSB,y_coord_MSB,y_coord_LSB;
if(mode == GetTouchStatus){
putc(0x6F); //cmd, get touch cordinates
putc(GetTouchStatus);
while(!kbhit(LCD))
delay_us(1);
x_coord_MSB = getc(LCD); //read characters from UART
x_coord_LSB = getc(LCD);
y_coord_MSB = getc(LCD);
y_coord_LSB = getc(LCD);
return x_coord_LSB; //status data is in x_coord_LSB
if(mode == GetTouchCoordinates){
putc(GetTouchCoordinates);
while(!kbhit(LCD))
delay_us(1);
G_xplace = make16( x_coord_MSB,x_coord_LSB); //make globals G_xplace && G_yplace
G_yplace = make16( y_coord_MSB,y_coord_LSB);
return mode; //returns 5 and set G_xplace && G_yplace
void show_freq_level(int8 wave_mode,int8 divider,int1 show_freq){
/* wave_mode 1 = sine, 2 = triangle 3 = square
to measure frequence put pulses from XR2206 pin 11 to A4 pin and use timer_0
and use FET BS170 as level converter to +1..+3 to 0...+5 V level
int32 freq;
static int32 old_freq;
int32 old_value;
int32 value;
static unsigned int old_thous, old_hunds, old_tens, old_ones;
//fREQUENCE ...............................................................................
if( show_freq == TRUE){
set_timer0(0);
setup_timer_0(RTCC_EXT_L_TO_H);
//use timer(1) interrupt for 1 s gate time:
set_timer1(1);
SETUP_TIMER_1(T1_INTERNAL | T1_DIV_BY_8);
//pulses to A4 pin and use timer_0 (same to RTTC)
SETUP_TIMER_1(T1_INTERNAL | T1_DIV_BY_8); //overflow interrupt every 104.858ms if div 8
set_timer0(0);
//high_freq is global,it is set or reset in analog_gen()
if(g_high_freq == FALSE){ //freq. 20 ... 20000 Hz
set_timer1(60400);
g_ints = 0;
set_timer0(0);
while(g_ints < 20); //wait for gate time 1s , res. 1 Hz
freq = get_timer0();
if(g_high_freq == TRUE){ //freq. 20000 ... 200000 Hz
set_timer1(6050); //this number is experiantal!
g_ints = 0;
set_timer0(0);
while(g_ints < 2); //wait for gate time 0.1 s , res. = 10 Hz
freq = freq * 10;
disable_interrupts(INT_TIMER1);
disable_interrupts(GLOBAL);
//show frequence:
putc(0x73); //cmd write text string
putc(16); //column in character units
putc(3); //row in character units
putc(0x03); //font 8 x 12
putc(0xF8); //string colour red
putc(0x00);
printf("%06Lu",freq);
com_ok();
//show frequence only if frequence has changed:
if(old_freq != freq){
//clear old frequence:
putc(0xFF); //string colour white
putc(0xFF);
printf("%06Lu",old_freq);
com_ok();
//then write new frequence:
putc(0x00);
com_ok();
old_freq = freq;
// LEVEL ......................................................................................
/*measure signal level, pin A0 is A/D converter input and signal is rectified...
with external circuit board ... so A/D measures DC voltage
sine wave 4 Vpp is number 558 from A/D
( TESTIT trimmaa lopullisella powerilla)
so 4 Vpp is 4000 mVpp...number 558 equals number 4000 so multiplier is number 7.1685
(resolution here is about 8 mV)
first multiplier value = value * 7168, then divide result with 1000*/
setup_adc_ports(AN0_ANALOG ); // pin A0 measures voltage level
setup_adc( ADC_CLOCK_INTERNAL );
delay_ms(2);
value = read_adc(); //A/D conversion
delay_ms(20); //OK delay for AD conversion testit
value = (value * 7168) /1000; //peak to peak value sine wave*/
value = value / 10; //rounding value because resolution is 10 bits
value = value * 10;
switch(wave_mode)
case sine: //default OK for sinewave
case triangle:
value = value * 125;
value = value / 100;
case square:
value = value * 65;
switch(divider)
case 0:
output_low(att_gain_1), //+20 dB gain relay off
output_low(att_gain_2), //+20 dB gain relay off
value = value; //no attenuation, no gain
case 1: //-20dB attenuation
output_high(att_gain_1), //+20 dB gain relay on
value = value / 10;
case 2: //-40dB attenuation
output_high(att_gain_2), //+20 dB gain relay on
//show new level digits only if they are changed:
delay_ms(50); //???????????????????? ei kai trvita
//update value:
putc(5); //row in character units
putc(0xFF);
printf("%04Lu",value);
com_ok();
putc(0x00);
com_ok();
old_tens = g_tens;
old_ones = g_ones;
//split_number(value); //digits to global variables g_thous, g_hunds, g_tens and g_ones;
if((g_thous != old_thous)){
//clear digit thousands, write old_thousands white:
putc(0xFF);
com_ok();
//print new digit thousands:
putc(0x00);
com_ok();
if((g_hunds != old_hunds)){
//clear digit hundreds, write old_hundreds white:
putc(17); //column in character units
putc(0xFF);
com_ok();
//print new digit hunds:
putc(0x00);
com_ok();
if((g_tens != old_tens)){
putc(18); //column in character units
putc(0xFF);
com_ok();
putc(0x00);
com_ok();
if((g_ones != old_ones)){
putc(19); //column in character units
putc(0xFF);
com_ok();
putc(0x00);
com_ok();
old_value = value;
void analog_gen(void){
int1 show_freq,run;
int8 onoff_mode,oldonoff_mode, range,divider,mode,loop,wave_mode,pot_delay;
int16 delay;
float f_offset = 0 ;
pot_delay = 1;
ret_offset_RESET(); //returns 0 V offset voltage after RETURN or RESET
//ret_offset(); //returns 0 V offset voltage after RETURN
//first these settings:
output_high(rel_20Hz); delay_ms(5); //A5, 20Hz relay and 20Hz sine filter ON
pot_delay = 5;
//g_offset_wiper = 0;
onoff_mode = 5; //first no output, button reads "RUN"
output_high(DA_cs); //D/A converter not selected
delay_ms(1);
output_low(ext_d_port); //ext d-port selected
delay_ms(1);
output_low(on_off_rel); //D0, signal on/off relay off
delay_ms(20);
freq_area(Hz200); //20...200 relay ON
divider = 0; //no attenuation 0dB
atten_rel(divider);
sel_wavemode(sine); //sinewave relay ON
G_xplace = G_yplace = 0;
an_buttons(); //draw analog buttons
/*write default values: range = 1(20...200Hz),mode = 1 (sinewave), divider = 1 (1/1)
offset = 0 V */
mode = 0;
range =1;
wr_range(range); //frequence range default value =1 = 20-200Hz
freq_area(range); //frequence relay ON first 20...200Hz area
g_high_freq = FALSE;
wr_divider(0);
//offset_V 0V...+-2.2V
//ret_offset(); //returns 0 V offset voltage after RETURN or RESET
wr_offset(f_offset); //default value 0.00 V
f_offset = 0;
en_touch_screen();
wave_mode = sine;
show_freq = FALSE;
anadisp_init(show_freq);
do{ //DO until RETURN pressed
mode = GetTouch(GetTouchStatus);
do{
show_freq_level(wave_mode,divider, show_freq);//measure and show freq. && signal level
}while(mode != TouchPress); //wait touch press
//show freq button pressed:
if((G_xplace > 190) && (G_xplace < 310) && (G_yplace > 44) && (G_yplace < 64)){
if(show_freq == FALSE)
show_freq = TRUE;
show_freq = FALSE;
//(G_xplace && G_yplace are global identifiers)
//freq.range button pressed:
if((G_xplace > 9) && (G_xplace < 171) && (G_yplace > 9) && (G_yplace < 35)&& (run == FALSE)){
do{
++range;
if(range == 5) //freq.range 1...4
range = 1;
if(range < 4)
g_high_freq = FALSE; //1s gate time to number 16 bits 65535 Hz
if(range == 4) //0.1s gate time to number 200000 Hz max.
g_high_freq = TRUE;
wr_range(range); //write freq.area to display
}while(mode != TouchRelease); //wait touch release
//divider button pressed:
if((G_xplace > 9) && (G_xplace < 171) && (G_yplace > 131) && (G_yplace < 155)){
do{
if(divider < 4) //divider 0dB = 0, -20 = 1 and -40 dB = 2
++divider;
if(divider == 3)
divider = 0;
wr_divider(divider);
atten_rel(divider);
//sinewave button pressed:
if((G_xplace > 9) && (G_xplace < 171) && (G_yplace > 39) && (G_yplace < 65)&& (run == FALSE)){
sel_wavemode(sine);
redraw_mode(1); // sine button
show_freq = FALSE;
mode = 0;
range =1;
//offset = 0;
if(onoff_mode == 5) //mode OFF, button reads RUN
redraw_mode(4);
if(onoff_mode == 4){ //mode ON, button reads OFF
redraw_mode(5);
output_high(on_off_rel); //output relay ON
wave_mode = sine;
//show_freq_level(sine); //measure and show freq. && signal level
do{
//triangle button pressed:
if((G_xplace > 9) && (G_xplace < 171) && (G_yplace > 69) && (G_yplace < 95) && (run == FALSE)){
delay_ms(20);
delay_ms(20);
redraw_mode(4);
//mode = 2; //mode triangle wave
redraw_mode(triangle);
sel_wavemode(triangle); //sinewave relay ON
wave_mode = triangle;
do{
//square button pressed:
if((G_xplace > 9) && (G_xplace < 171) && (G_yplace > 99) && (G_yplace < 125)&& (run == FALSE)) {
delay_ms(20);
delay_ms(20);
redraw_mode(4);
//mode = 3; //mode square wave
redraw_mode(square);
sel_wavemode(square); //square relay ON
//show_freq_level(square); //measure and show freq. && signal level
wave_mode = square;
do{
//+ offset button pressed:
if ((G_xplace > 121) && (G_xplace < 139) && (G_yplace > 159) && (G_yplace < 185)){
delay = 500; loop = 0;
do{
//f_offset = f_offset + 0.04;
--g_offset_wiper;
delay_ms(delay);
if(loop > 5) delay = 1;
//set offset towards positive voltage:
output_high(pot_cs); //dig. pot not selected
delay_ms(pot_delay);
output_low(pot_up_down); //dig.pot wiper LOW, makes offset V higher!
output_high(pot_inc);
output_low(pot_cs); //dig. pot selected
//output_high(pot_inc); //pulse dig. pot, store
output_low(pot_inc); //pulse dig. pot, no store
++loop;
}while ((mode != TouchRelease) && (f_offset < 2)); //wait touch release
//- offset button pressed:
if((G_xplace > 153) && (G_xplace < 169) && (G_yplace > 159) && (G_yplace < 185)){
do{
f_offset = f_offset - 0.04;
++g_offset_wiper;
delay_ms(delay);
if(loop > 5)
delay = 1;
//set offset towards negative voltage:
output_high(pot_up_down); //dig.pot wiper HIGH, makes offset V [spam]!
++loop;
}while ((mode != TouchRelease) && (f_offset > -2)); //wait touch release
//RUN button pressed:
//if((G_xplace > 9) && (G_xplace < 118) && (G_yplace > 199) && (G_yplace < 230)){
if((G_xplace > 9) && (G_xplace < 94) && (G_yplace > 199) && (G_yplace < 230)){
if(onoff_mode == 5){ //mode to ON, button reads OFF AFTER PRESS!
run = TRUE;
wait_delay(); //wait generator to setup few seconds
output_high(on_off_rel); //D0, signal on/off relay to ON
delay_ms(5);
redraw_mode(5);
oldonoff_mode = 5;
if(onoff_mode == 4){ //mode to off, button reads RUN AFTER PRESS!
run = FALSE;
delay_ms(5);
redraw_mode(4);
oldonoff_mode = 4;
if(oldonoff_mode == 4){ //mode ON, button reads OFF
onoff_mode = 5;
if(oldonoff_mode == 5){ //mode OFF, button reads RUN
onoff_mode = 4;
do{
delay_ms(20);
//DIST button pressed:
if((G_xplace > 203) && (G_xplace < 298) && (G_yplace > 201) && (G_yplace < 236)) {
dist_meter();
// OK digi_gen();
do{
Mike Walne
Posted: Fri Mar 20, 2015 10:56 am |
Like asmboy says, you need to tell us:-
1) What your code is intended to do.
2) What works.
3) What it's actually doing wrong.
It would also be useful if you could reduce your post to a SHORT, COMPLETE, COMPILABLE code which shows the problem.
(Say 15 lines MAX.)
Most of the guys here (the ones who could help) are not prepared to wade through several page full of irrelevant material.
Mike |
artohautala
Posted: Fri Mar 20, 2015 11:24 am |
Mike Walne wrote: | Like asmboy says, you need to tell us:-
2) What works.
(Say 15 lines MAX.)
Mike |
Hello Mike,
and lot of thanks you answering me ...
the main problem is shortly here :
why I can't send parameters to my function
old_value = 0;
value = 1357;
but this work fine:
com_ok();
com_ok();
com_ok();
com_ok();
com_ok();
com_ok();
com_ok();
com_ok();
//print 100.0 %
com_ok();
e:;goto e;
old_value = 1357;
value = 0;
but this work fine:
com_ok();
com_ok();
com_ok();
com_ok();
com_ok();
com_ok();
com_ok();
com_ok();
//print 100.0 %
com_ok();
e:;goto e;
Mike Walne
Posted: Fri Mar 20, 2015 12:07 pm |
You're still not getting it.
Please:-
a) Use the code button.
b) Reduce your code to about 15 lines MAX.
c) Read the forum guidelines.
I (and many others) will not wade through pages of code.
You're the one wanting help, we've got better things to do.
Make it easier for us to help you.
Mike |
