Can't seem to locate a function within a segment
Gazza
PostPosted: Mon Mar 09, 2015 4:25 am     Reply with quote
Hi guys,
My problem is fixing a function address within a segment, I need "LoaderExec()" to be fixed at 0xfc00. The loader will be installed using the #import(FILE=..., HEX, RANGE=0xFC00:0xFFFF) function.
#define LOADER_START 0xfC00
#org LOADER_START, 0xFFFB default
void LoaderExec() { .. }
// Other loader functions ad commands intrepeter
void __LoaderhInit();
// Initialise ROM 0 to point at LoaderExec
  ZP_ROM [0]=make8(LOADER_EXEC,0);
  ZP_ROM [1]=0xef;
  ZP_ROM [2]=make8(LOADER_EXEC,1);
  ZP_ROM[3]=0xF0;
reset_CPC();
#org 0xFFFC, 0xFFFF
void LoaderInit()
__LoaderhInit();
#org default
When I compile this the functions locate as follows:
ROM Allocation:
00FC00  CRC32
00FC54  GetHexDigit
00FC76  @@FLASHWR
00FC96  @@WRITE_PROGRAM_MEMORY
00FCD8  BlockToRom
00FDC4  ExecCommand
00FF28  LoaderExec      <<==============
00FFCA  __LoaderInit
00FFFC  LoaderInit
How do I get LoaderExec to locate at 0xfc00. I know I can create an address using "__ADDRESS__ LoaderExec;" but this has ROM overheads which I have little free space for.
At the moment I am copying the address of LoaderExec() from the .sym file and plugging it in to __LoaderhInit() via “LOADER_EXEC”, this cannot be right.
Any help will be gratefully received.
Gaz
PostPosted: Mon Mar 09, 2015 4:34 am     Reply with quote
The problem is the use/understanding of 'default'.
This makes the compiler put all the compiler library routines also into the same segment. These are always put first.
You'd need to assign these to somewhere in the required segment (since you presumably want these as well, to make the routine work), as a separate #org, and then do an org without using default, where you want to put the routine. Note how 'LoaderInit', which doesn't have the 'default' declaration goes where you want it.
As a comment, you can always get the address, with 'label_address'.
Gazza
PostPosted: Mon Mar 09, 2015 5:16 am     Reply with quote
Thanks for the reply Ttelmah,
I understand what you say about “default” and it makes perfect sense.
Does this not mean then that I need to know the actual length of LoaderExec() function to enable me to fix the remaining functions at the correct place in ROM. Again copying data from the .sym file.
Ex.
#org 0xfc00, <0xfc00+lengh_of_ LoaderExec>
void LoaderExec() {…}
#org < 0xfc00+lengh_of_ LoaderExec + 1 >, 0xFFFB default
… Rest of the loader.
The problem seems to have shifted from knowing the address of the routine to knowing its length.
Gazza
PostPosted: Mon Mar 09, 2015 5:41 am     Reply with quote
Trying to use compiler functions to get an address as in "label_address" works in the only in on a label in the current function. Creating an address variable the __ADDRESS__ type adds too much compiler overhead.
All I really need is the compiler to supply a 16 bit number of a fixed address which it already knows because its in the .sym file.
Not to worry, I'll have to stick with hard coding the address from the sym file each time I compile the loader for a different micro.
PostPosted: Mon Mar 09, 2015 6:01 am     Reply with quote
I think you can solve the problem by doing the declarations separately.
So:
//Makes this the default segment
..Now put 'LoaderExec' at the start of the same segment.
This tells the compiler to use the required segment for the default code, and then to put the LoaderExec function at the start of this segment.
Since 'default' is already specified the default routines should go into the same segment, but should now go after the routine.
