Mach X - Placement of 12F IC
jaikumar
PostPosted: Tue Feb 24, 2015 1:37 am     Reply with quote
Hi All,
I would like to program the PIC12F675 8 pin IC.
How and where to place in the Mach-X 40 PIN Socket.
Is there a manual or help file showing the placement.
Thanks and Regards,
Jay.
PostPosted: Tue Feb 24, 2015 6:18 am     Reply with quote
If it's like the PICStart-Plus I have, pin one of the PIC always mates with pin one of the programmer, # of pins doesn't matter (8, 18 or 40).
That info should be in the manual though....
Jay
jaikumar
PostPosted: Tue Feb 24, 2015 6:45 am     Reply with quote
I tried first pin of chip with first pin of
Socket does not work.
PostPosted: Tue Feb 24, 2015 7:39 am     Reply with quote
I'd contact CCS tech support. I looked at the online info and it should support it as it's in the list of supported devices.
This forum is more about actual C code, not physically programming the PICs, though others who use Mach-X may reply, CCS tech support is who I'd email ASAP!
Jay
PostPosted: Tue Feb 24, 2015 8:22 am     Reply with quote
It certainly does program with pin1=pin1 in the Mach-X.
Make sure you have current firmware in the Mach-X, and the current software.
jaikumar
PostPosted: Thu Feb 26, 2015 5:53 am     Reply with quote
Thanks Ttelmah,
It worked after updating both the loader and the firmware.
Thanks,
Jay.
