CCS bootloader
Linuxbuilders
CCS bootloader
PostPosted: Tue Feb 24, 2015 3:26 am     Reply with quote
Hi Everybody,
I know there is many posts about it but none seem to answer few important questions.
https://pic-c.com/forum/viewtopic.php?t=45044 THIS ONE TOO...
- We are talking about - ex_bootloader.c and related files
- I use two pics 18F4520 and 18F4620
Questions:
1. Is there anybody who could explain like to a child how to calculate those 2 entries for each MCU
#define LOADER_END   0xXXXX
#define LOADER_SIZE  0xXXXX
DATASHEET was looked at.
2. Then what value is to be placed in:
#if defined(__PCH__)
#org 0x40,0xXXXX
3. Do I need to modify the HEX I load into the system from the bootloader level or is this HEX unchanged? Do I need to add any #ORG entries to protect the bootloader block or not?
I seem to run in the circles and it is just a waste of time so some nice clear answer would be appreciated as it seem to be common issue with this file.
Thank you for any help.
Help "d" others and then you shell receive some help from "d" others.
PostPosted: Tue Feb 24, 2015 8:27 am     Reply with quote
You don't calculate these entries.
You compile _your_ bootloader. Look at how large it is, and put in the end figure, the top byte under next page boundary above the size of you code.
Linuxbuilders
PostPosted: Wed Feb 25, 2015 1:09 am     Reply with quote
Do I need to modify the program which is to be run by the bootloader, I mean tell it where is the reset vector, where bootloader is placed, etc? Or do I just compile it as normally like if there would be no bootloader in the system?
Then I think nobody here really had a look at the datasheet at all, I place it then for easy understanding. I guess that is why the posts about this MCU are not resolved.
So could you please help here. I am a bit confused here how to operate on pages which are not listed, etc.
Rom makes not much too here:
ROM Allocation:
0080  @delay_ms1
001E  @delay_us1
00DE  @PUTCHARI_BIU_1
00AA  @GETCH_BIU_1
04CE  real_load_program
046C  @14@FLASHWR
048C  @14@WRITE_PROGRAM_MEMORY
040A  atoi_b16
0400  load_program
0800  application
0040  MAIN
0008  isr
0040  @cinit
Thank you
PostPosted: Wed Feb 25, 2015 1:28 am     Reply with quote
Look at ex_bootload.c
The program needs to be relocated to avoid the bootloader. This shows how to perform this relocation. Note how it includes bootloader.h, but without defining the keyword "_bootloader". This tells it to perform the relocation only.
Linuxbuilders
PostPosted: Wed Feb 25, 2015 1:54 am     Reply with quote
So if I understand it correctly based on my compilation my
#org 0x40,0x3FF
and
#define LOADER_END   0x7FF
#define LOADER_SIZE  0x400
Would that be correct based on below?
0400  load_program - 1 = 3FF
0800  application - 1 = 7FF
7FF-3FF = 400
PostPosted: Wed Feb 25, 2015 2:44 am     Reply with quote
I doubt it.
Just use the bootloader.h. If you need a different LOADER_END address, just #define this before loading bootloader.h. It does everything else. It generates loader size for you, from loader_end. It calculates the #ORG etc..
Linuxbuilders
PostPosted: Wed Feb 25, 2015 3:00 am     Reply with quote
As instructed, left it alone. After compilation it looks like this:
ROM Allocation:
0514 @delay_ms1
001E @delay_us1
0572 @PUTCHARI_BIU_1
053E @GETCH_BIU_1
01CE real_load_program
016C @24@FLASHWR
018C @24@WRITE_PROGRAM_MEMORY
010A atoi_b16
0100 load_program
0500 application
0040 MAIN
0008 isr
0040 @cinit
Then I have used EX_BOOTLOAD.C to check if it will work, no go, does not boot up. Ideas?
Linuxbuilders
PostPosted: Wed Feb 25, 2015 3:17 am     Reply with quote
Got it working,
no change required, just compile and load, then modify the main program as per instructions.
However it is chaotic, it enters bootloader every second reset - I will have to look at my input.
Thnx
PostPosted: Wed Feb 25, 2015 5:18 am     Reply with quote
I'd be looking at the pullup resistor on the input.
