vortexe90
#RDA does not work with Bootloader include |
Posted: Sat Feb 21, 2015 6:29 am |
Hi guys, I am trying to develop a program in CCS Compiler Version 5 on RS232 communication between two PIC 18F4550 and 18F4620 I use #RDA interruption for the reception and it works very well except that I a problem when I included the "Bootloader.h" in this case the bootloader works well but it causes me a problem at #RDA because it does not work.
All work well without include bootloader.
Please a solution to this problem ...
This is my CCS prog:
Code: | #include <18F4620.h>
#device ADC=10
#FUSES PUT //Power Up Timer
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES NOWRTC //Configuration registers not write protected
#use delay(crystal=27000000)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
//#use rs232(baud=9600,parity=N,xmit=PIN_B7,bits=8,stream=xbee)
#include <bootloader.h>
volatile float Voltage_IV[75];
volatile float Current_IV[75];
volatile float Power_IV[75];
int w, incr1 = 0;
#INCLUDE <stdlib.h>
#include <string.h>
#include <tones1.c>
#include <ds1307.c>
#include <24512MODIF.c>
#include <external_eeprom.c>
#include <Extended_GLCD.c>
#include "menu.c"
signed int enc_states[] = {0,-1,1,0,0,0,0,0,0,0,0,0,0,1,-1,0};
int16 enc_position = 0;
int16 old_enc_value = 0;
//volatile int counter_read=0;
volatile Char Recieve_String[6];
volatile Char volt[4];
volatile Char current[4];
volatile Char Irr[5];
volatile Char Tmp[5];
#int_rb
void Encoder_signal(void)
enc_position >>= 2; // shifting the lower bits up 2
enc_position |= ( input_b() & 0B00110000 ); //port b, then OR them with var //old_AB to set new value
enc_value += enc_states[( enc_position & 0x0f )];
if ( enc_value == old_enc_value ) { return;}
old_enc_value = enc_value;
#int_RDA
void RDA_isr(void)
gets(Recieve_String);
//_______________________________________________________
if (Recieve_String[0] == 'V')
memmove(Recieve_String,Recieve_String+1,6);
strncpy(volt, Recieve_String,3);
keepv = atof(volt);
maxvtab[i] = keepv * 6;
Recieve_String[12] = 0;
if (Recieve_String[0] == 'C')
strncpy(current, Recieve_String,3);
keepi = atof(current);
maxitab[i] = keepi * 2;
if (Recieve_String[0] == 'T')
strncpy(Tmp, Recieve_String,5);
keepTmp = atof(Tmp);
maxTmptab[i] = keepTmp;
if (Recieve_String[0] == 'I')
strncpy(Irr, Recieve_String,4);
keepIrr = atof(Irr);
maxIrrtab[i] = keepIrr;
if (Recieve_String[0] == 'A')
strncpy(volt2, Recieve_String,(strlen(Recieve_String)-1));
vtab = atof(volt2);
Voltage_IV[w] = vtab;
w++;
incr1++;
if (incr1==2) {incr1 = 0; incr++;}
if (Recieve_String[0] == 'B')
strncpy(current2, Recieve_String,(strlen(Recieve_String)-1));
itab = atof(current2);
Current_IV[w] = itab;
w++;
incr1++;
if (Recieve_String[0] == 'F')
nextvalue = 1;
setup_adc_ports(AN0|VSS_VDD);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
//setup_ccp1(CCP_PWM|CCP_SHUTDOWN_AC_L|CCP_SHUTDOWN_BD_L);
setup_timer_2(T2_DIV_BY_1,224,1); //33,3 us overflow, 33,3 us interrupt
enable_interrupts(INT_RB);
//R = (700 * log10(2))/(log10(897));
glcd_init(ON);
ds1307_init();
init_ext_eeprom();
glcd_image(YES);
//for (int16 v = 0; v <= 637; v++) {set_pwm1_duty(fade[v]); delay_ms(3);}
generate_tone(D_NOTE[3], 100);
enable_interrupts(INT_RDA);
enc_value = 1;
PRmenu();
while (true)
while (inter == 1)
Sub_scrolling_PRmenu();
while (inter == 2)
Lantch_IV_PV_extractor();
if (choose == 1) { cadran_IV_PV(); choose = 0;while( !input(valid) ) {}
while (input(valid)){}}
delay_ms(50); disable_interrupts(INT_RDA);
enable_interrupts(INT_RB);acces_menu1 = 1;
enc_value = 3; inter = 0;PRmenu();
while (inter == 3)
Voltage_measuring_and_ploting();
Current_measuring_and_ploting();
while (inter == 4)
Irradiation_measuring_and_ploting();
Temperature_measuring_and_ploting();
while (inter == 5)
Panel_Parameters();
delay_ms(1500);
enc_value = 1; inter = 0;PRmenu();acces_menu1 = 1;
while (inter == 6)
while( !input(valid) ) {if (enc_value <= 29) {enc_value = 29;}
if (enc_value >= 79) {enc_value = 79;}
set_pwm1_duty(fade[enc_value * 8]);
glcd_setxy(40,30,1,1);
printf(glcd_putc57, "%Lu ",((enc_value - 29)*2)); }
while (input(valid)){} enc_value = 1; inter = 0;
while (inter == 7)
diag_report();
while (!input(valid)) {}
while (input(valid)) {}
enc_value = 3; inter = 0;PRmenu();acces_menu1 = 1;
scrolling_PRmenu();
This the bootloader
#fuses NOWDT
#use delay(crystal=27MHz)
#use rs232(baud=57600, xmit=PIN_A3, rcv=PIN_A2)
#define PUSH_BUTTON PIN_A4
#define _bootloader
#include <loader.c>
#org LOADER_END+2,LOADER_END+4
void application(void) {
while(TRUE);
void main(void) {
if(!input(PUSH_BUTTON))
printf("\r\nBootloader Version 1.0\r\n");
// Let the user know it is ready to accept a download
printf("\r\nWaiting for download...");
load_program();
application();
#int_global
void isr(void) {
jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
Posted: Sat Feb 21, 2015 1:27 pm |
First, the _bootloader_ needs all the fuses. Get rid of them in the runtime. Personally I use #fuses NONE in the runtime code. You can't change fuses in the application, from what the bootloader has.
Then your interrupt is fundamentally flawed. INT_RDA, means _one_ character is available. Just one. Do a search here for why you should never use gets in the interrupt. I'd suspect your failure is actually caused by the extra delay on boot, and the interrupt not functioning as you expect, rather than the bootloader itself.... |
