ELCouz
Input Capture.... |
Posted: Fri Feb 20, 2015 5:25 pm |
I've seen that many things have changed (compiler wise) since my last project with CCP in 2007 (somewhere around V4.045)...
Now on the PIC24HJ128GA010 I have 5 Input Capture module...
Do this old code (for v3 wrote by PCM Programmer, to read signal frequency) still apply to the current gen compiler (v5.042):
#include <18f2553.h>
#fuses HSPLL,PLL3,CPUDIV1,NOWDT,NOPROTECT,NOLVP,NODEBUG,NOMCLR
#use delay(clock=48000000)
#define BytePtr(var, offset) (char *)(&var + offset)
#byte PIR1 = 0xF9E
#bit TMR1IF = PIR1.0
#byte CCPR1_REG = 0xFBE
#byte T1CON = 0x8F
// This global variable holds the time interval
// between two consecutive rising edges of the
// input signal.
int16 isr_ccp_delta;
int32 g32_ccp_delta;
char gc_timer1_extension;
BOOLEAN gc_capture_flag;
#int_timer1
void timer1_isr(void)
gc_timer1_extension++;
// When a rising edge occurs on the input signal,
// the CCP1 will 'capture' the value of Timer1
// at that moment. Shortly after that, a CCP1
// interrupt is generated and the following isr
// is called. In the isr, we read the 'captured'
// value of Timer1. We then subtract from it the
// Timer1 value that we 'captured' in the previous
// interrupt. The result is the time interval
// between two rising edges of the input signal.
// This time interval is then converted to a frequency
// value by code in main().
#int_ccp1
void ccp1_isr(void)
char timer_ext_copy;
int32 current_ccp;
static int32 old_ccp = 0;
// Set flag to indicate that we did a capture.
gc_capture_flag = TRUE;
current_ccp = (int32)CCP_1; // Read the current CCP
// Get local copy of the timer ext.
timer_ext_copy = gc_timer1_extension;
// Check if a Timer1 interrupt is pending. If so, check if
// the CCP capture occurred before or after the Timer rolled
// over. We can tell if it occurred after it rolled over, if
// the CCP's MSB is zero. ie., if the CCP is somewhere between
// 0x0000 and 0x00FF.
// We know that we can just check if the MSB = 0x00, because
// it takes about 30 us to get into this ISR. (Using a 4 Mhz
// crystal on a 16F628). The timer increments at 1 us per
// count, so 0xFF = 255 us.
// Actually, to be safer, I'll give it 2 MSB counts, which is
// 511 us. That way, if I lengthen any of the other ISR's,
// we'll still be able to detect the roll-over OK.
// If the timer did roll over after we got a CCP interrupt,
// then we need to increment the timer extension byte, that we
// save. We have to do that because the CCP interrupt has
// priority, and so it executes before the Timer isr can
// execute and increment the extension.
// (Designing the code with the priority switched doesn't help.
// You still have the same type of problem. With CCP first,
// the fix is easier).
// Was CCP captured after Timer1 wrapped ?
// If so, increment the copy of the timer ext.
if(interrupt_active(INT_TIMER1))
if(*BytePtr(current_ccp, 1) < 2)
timer_ext_copy++;
// Since we know a timer interrupt is pending, let's just
// handle it here and now. That saves a little load off
// the processor.
gc_timer1_extension++; // Increment the real timer extension
clear_interrupt(INT_TIMER1); ; // Then clear the Timer1 interrupt
// Insert the timer extension into the proper place in the
// 32-bit CCP value.
// ie., Insert it into location "EE" as follows: 0x00EEnnnn
// (nnnn = the CCP).
*BytePtr(current_ccp, 2) = timer_ext_copy;
// Because we're using unsigned math, we don't have to worry
// if the current value is less than the old. The result is
// always the absolute value of the difference. The only way
// there could be a problem is if the new CCP value had rolled
// over twice. But with a 24-bit value, and a Timer
// pre-scalar of 1, that's 16.7 seconds. That's way beyond any
// practical value.
// Edited on Jan. 2, 2004: There was a bug in this routine,
// because I was promoting a 24-bit value to a 32-bit data type,
// but the upper byte was always left = 0. This caused a problem
// with the 32-bit subtraction when the 24-bit value rolled over past 0.
// Kenny spotted this error and provided a fix in a PM to me.
// I have commented out the original line, and inserted his fix, below.
//g32_ccp_delta = current_ccp - old_ccp;
g32_ccp_delta = (current_ccp > old_ccp) ? current_ccp - old_ccp : current_ccp + (0x1000000 - old_ccp);
// Save the current ccp value for next time.
old_ccp = current_ccp;
int32 current_ccp_delta;
int16 frequency;
delay_us(20);
// Setup Timer1 and CCP1 for Capture mode so that
// we can measure the input signal's frequency.
// The input signal comes from the CCP2 pin, which
// is connected to the CCP1 pin with a wire.
set_timer1(0);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_CLK_OUT);
setup_ccp1(CCP_CAPTURE_RE);
// Clear the CCP1 interrupt flag before we enable
// CCP1 interrupts, so that we don't get an unwanted
// immediate interrupt (which might happen).
clear_interrupt(INT_CCP1);
enable_interrupts(INT_CCP1);
// Now calculate the frequency.
// Get a local copy of the latest ccp delta from the isr.
// We have to disable interrupts when we read a global
// isr variable that is larger than a single byte.
disable_interrupts(GLOBAL);
current_ccp_delta = g32_ccp_delta;
// To calculate the frequency of the input signal,
// we take the number of clocks that occurred
// between two consecutive edges of the input signal,
// and divide that value into the number of Timer1
// clocks per second. Since we're using a 4 MHz
// crystal, the Timer1 clock is 1 MHz (Timer1 runs
// at the instruction cycle rate, which is 1/4 of the
// crystal frequency). For example, suppose the
// the input waveform has a frequency of 244 Hz.
// 244 Hz has a period of about 4098 usec.
// Timer1 is clocked at 1 MHz, so between two
// consecutive rising edges of the input signal,
// it will count up by 4098 clocks. To find the
// frequency, we divide 4098 into the number of
// clocks that occur in 1 second, which is 1000000.
// This gives 1000000 / 4098 = 244 Hz.
if(gc_capture_flag == TRUE)
frequency = (int16)((32768L + (current_ccp_delta >> 1)) / current_ccp_delta);
printf(" %lu Hz ", frequency);
gc_capture_flag = FALSE;
printf(" No signal ");
I've seen new functions like #use capture / get_capture
Any example snippet of code for the "new features" to read the frequency (PIC24 compatible) ?
Thank you very much! _________________ Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy! |
ELCouz
Posted: Sat Feb 21, 2015 12:18 am |
I noticed that I don't have the ex_capture.c file. I guess you only get it if
you have the PCD compiler.
I looked at the .LST file and I note that the #use capture() library doesn't
use interrupts for the PCM and PCH compilers. It does it by software
polling of the CCP interrupt flag in the PIR1 register. So I have to say
my "old" code is better.
The code below is a simple demo of #use capture() and #use pwm().
If the signal is not present, the code will stay stuck in a while() loop
forever. But it does work. Here is the output on the TeraTerm window:
Start
500.0 Hz
500.0 Hz
500.0 Hz
500.0 Hz
500.0 Hz
500.0 Hz
500.0 Hz
Code: | #include <18F4620.h>
#fuses INTRC_IO, BROWNOUT, PUT, NOWDT
#use delay(clock=4M)
// Setup CCP1 to capture on the rising edge
// of the input signal on Pin C2. Run Timer1
// with a divisor of 1, by selecting "FASTEST".
#use capture(CCP1, FASTEST, CAPTURE_RISING)
// Use CCP2 to generate a 500 Hz test signal
// on Pin C1. Connect it to the CCP1 input
// with a jumper between pins C2 and C1.
#use pwm(CCP2, FREQUENCY=500, DUTY=50)
int16 first_timer_value;
int16 second_timer_value;
int16 capture_time;
float frequency;
printf("Start\n\r");
first_timer_value = 0;
second_timer_value = 0;
capture_time = 0;
while(!get_capture_event());
first_timer_value = get_capture_time();
second_timer_value = get_capture_time();
capture_time = second_timer_value - first_timer_value;
frequency = (float)(getenv("CLOCK")/4) / capture_time;
printf("%7.1f Hz \n\r", frequency);
