How to run dspic33ep256mu806 at maximum MIPS?
Goto page 1, 2  Next
umarkhan
PostPosted: Tue Jan 06, 2015 6:04 am     Reply with quote
hello,
I am currently using a dspic33ep256mu806 and wish to run it at the maximum speeds mentioned in the data sheet which vary between 60-70 MIPS. I do not know if I am testing it in the correct way, but I have written a simple code the uses an output_high command followed immediately by an output_low command in a while loop. I expect a pulse at the corresponding output pin to be about 14-16 ns. In addition I have used
a) the #use delay directive to set the clock to 120M using the PLL.
b) the #use fast_io directive to minimize the resulting assembly code.
My final code is as follows,
//includes
#include <33EP256MU806.h>
#fuses PR_PLL
#fuses PLLWAIT
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#use delay(clock=120M, xtal=8M)
   output_high(28821);
     #use fast_io(B)
     output_high(28821);
     output_low(28821);
     delay_us(100);
I get the following trace on the output pin which is about 40ns Crying or Very sad
post images
any pointers will be welcome,
Umar.
PostPosted: Tue Jan 06, 2015 8:46 am     Reply with quote
It's more like 33nSec. Look at where the signal starts to move.
Exactly half what you'd expect.
What compiler version?.
If you look at the code, it generates:
....................      output_high(28821);
0021E:  BSET.B  E14.5
....................      output_low(28821);
00220:  BCLR.B  E14.5
I don't like the coding style at all. Use the pin names, not numbers that can go wrong, and remember that #use fast_io, is not a line of code, but a pre-processor directive. However these don't stop it working.
Are you sure your crystal is working, and at 8MHz?.
What happens if you try with the internal oscillator?.
The current compilers correctly sets CLKDIV to 0, and PLLFBD to 0x3A, which for 8Mhz in, gives:
Fosc = 8MHz * (0x3A+2)/(2+2) = 120MHz. So this is correct.
umarkhan
PostPosted: Tue Jan 06, 2015 10:43 am     Reply with quote
hi,
The compiler version is 4.130. I was originally using the #define to assign a name to the pin, but then thought that directly addressing the pin number might be a little faster. I use names for pins and will revert to the original method for later posts.
I tried using the internal oscillator using
#use delay(clock=120M, internal)
but this makes no difference. I checked the crystal and it correctly generates the 8M signal.
I suspect my compiler does not write to the CLKDIV and PLLFBD registers. This is because when I open the generated hex file in ccs I don't see the addresses 0x0744 and 0x0746 (CLKDIV and PLLFBD) any where, but do see the 0xF0006 and 0xF0008 addresses which correspond to the FOSCEL and FOSC.
Is there any way I can write directly to the CLKDIV and PLLFBD?
PostPosted: Tue Jan 06, 2015 11:42 am     Reply with quote
Yes, I'd definitely suspect compiler version. That is an old compiler for that chip.
You can simply declare the registers with a #word, and write to these, but you have to generate the unlock sequence first. Get the reference manual 70268A, and look at the section entitled 'clock switching'.
I think code to do this using #ASM was posted here at the time that your compiler dates from. A forum search should find it. Possibly by Ckielstra, or Temtronic?.
Have a look at this thread:
<http://www.ccsinfo.com/forum/viewtopic.php?t=49419&highlight=dspic33+clock>
I was going to say it is probably easier to wake up using FRC, program the PLL, and then switch, which is what he does.
PostPosted: Wed Jan 07, 2015 3:41 am     Reply with quote
Just an update. Checked 'old compilers', and a couple of versions earlier, this PIC is not present. 4.130, is one of the very earliest supporting the chip. Common for there to be problems for a few versions after a chip is added...
Half a dozen versions later, it is setting the clock up correctly.
ELCouz
PostPosted: Wed Jan 07, 2015 4:45 pm     Reply with quote
Last v4 was 4.141
Unless he want to jump the v5 bandwagon (which I did)
I remember the transition few years ago, V3 to V4 compiler was brutal ( and buggy )...
V3 was good until around V4.060
Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy!
newguy
PostPosted: Wed Jan 07, 2015 7:26 pm     Reply with quote
Last v4 was 4.141
I'm still not brave enough to try v5. Not worth the headache (in my evaluation) yet....until I find a chip that 4.141 doesn't support at all. Not that it supports the dsPIC I am using, but I have my code working absolutely flawlessly and I'm not going to risk inducing any funny things by upgrading to v5.
umarkhan
compiler test
PostPosted: Thu Jan 08, 2015 9:56 am     Reply with quote
hi Ttelmah,
We are investigating the possibility of an upgrade to the latest compiler, but we need to know if the latest compiler will actually solve the problem. As you mentioned that the latest compiler sets the CLKDIV and PLLFB registers correctly, would it be possible for you to send me the hex file compiled for the code i posted earlier by the latest compiler. If it works this would be very helpful in securing a purchase Smile
Umar
PostPosted: Thu Jan 08, 2015 10:24 am     Reply with quote
something to consider...
be sure to design the PCB for the speed !! you need proper layout,size of traces,bypass caps,smooth power,etc. to get any micro to run that fast and be reliable.
No amount of software will fix a faulty hardware design.
just food for thought.
Jay
oxo
PostPosted: Fri Jan 09, 2015 7:25 am     Reply with quote
OP, I'm using the same part, but it's not connecting. Are you using ICD-U64?
oxo
PostPosted: Mon Jan 12, 2015 12:08 am     Reply with quote
I should say its not connecting using PGEC1 and PGED1.
PostPosted: Mon Jan 12, 2015 1:27 am     Reply with quote
You are aware you need a revision 3 ICD-U64, to debug these chips?. Your existing unit can be modified to this revision.
oxo
PostPosted: Mon Jan 12, 2015 1:35 am     Reply with quote
Yes,
I had that issue a couple of weeks ago with the Explorer16.
What I have is my code running on the Explorer, but when I go to my own hardware it won't program.
The biggest difference is that the explorer uses a 33EP512MU810.
As always, it will be some stupid thing I missed.. probably.
I am trying the OPs code above and that won't program either.
PCWHD V 5.036
dsPIC33EP256MU806
oxo
PostPosted: Mon Jan 12, 2015 1:49 am     Reply with quote
Eugeneo
PostPosted: Mon Jan 12, 2015 2:14 am     Reply with quote
I can't test it since I don't have this particular chip, but it seems to be all there.
CCS PCD C Compiler, Version 5.036, 14388               12-Jan-15 01:10
               Filename:   C:\Micro\main.lst
               ROM used:   556 bytes (0%)
                           Largest free fragment is 65536
               RAM used:   128 (0%) at main() level
                           129 (0%) worst case
               Stack used: 0 locations
               Stack size: 128
00000:  GOTO    200
.................... #device DSPIC33EP256MU806
.................... #list
....................  #fuses PR_PLL
....................  #fuses PLLWAIT
....................  #FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
....................  #FUSES NOBROWNOUT               //No brownout reset
....................  #use delay(clock=120M, xtal=8M)
....................  void main()
00200:  MOV     #7F80,W15
00202:  MOV     #7FFF,W0
00204:  MOV     W0,20
00206:  NOP
00208:  BSET.B  8C1.7
0020A:  CLR     744
0020C:  MOV     #3A,W4
0020E:  MOV     W4,746
00210:  CLR     E1E
00212:  CLR     E2E
00214:  CLR     E3E
00216:  CLR     E4E
00218:  CLR     E6E
0021A:  BCLR.B  E10.5
0021C:  BSET.B  E14.5
....................     while(1)
....................       #use fast_io(B)
0021E:  BSET.B  E14.5
00220:  BCLR.B  E14.5
....................       delay_us(100);
00222:  REPEAT  #176E
00224:  NOP
00226:  GOTO    21E
0022A:  PWRSAV  #0
Goto page 1, 2  Next
Page 1 of 2
