8 bit read on a 16 bit port
Eugeneo
PostPosted: Fri Dec 26, 2014 3:42 pm     Reply with quote
Is it possible to port read the lower 8 bits of a 16 bit port without affecting the upper bit ports? I'm using the 8 LSBs of port_d as a bus and would like to use the upper ones as I/O.
Code for a int8 port read (CCS V5.016). It works but the compiler sets the entire port to input.
....................     i = input_d();
04BAE:  SETM    2D2                 <- Set the entire port to input
04BB0:  MOV.B   2D4,W0L
04BB2:  PUSH    33B4
04BB4:  MOV.B   W0L,[W15-#2]
04BB6:  POP     33B4
This code is modified to only set the required tris bits, but it doesn't work. Is there a way of doing this?
....................     bus_set_to_input;
04BB8:  SETM.B  2D2
....................     i = bus_port;
04BBA:  MOV.B   2D6,W0L
04BBC:  PUSH    33B4
04BBE:  MOV.B   W0L,[W15-#2]
04BC0:  POP     33B4
PostPosted: Sat Dec 27, 2014 1:38 am     Reply with quote
The obvious basic one it to switch to using fast_io.
With this selected, the compiler will not change the TRIS. So you can then just do a read on the port, and the upper bits will stay set as they were.
For a 'bus' type application, this is probably better anyway. Means you will have to set the tris on the other pins (either use the tris command, or output_drive and output_float), rather than it being set automatically.
The alternative is to bypass the CCS access for the low half of the port.
So:
#byte Low_D = getenv("SFR:PORTD")
    val = Low_D;
Will read the single byte from the low half of port D, without adjusting the tris.
Eugeneo
PostPosted: Tue Dec 30, 2014 8:31 pm     Reply with quote
Thank you. This worked!
Can you use these two directives one after another and expect the fixed directive to trump *only PIN_A2?
#use standard_io(a)
#use fixed_io(a_outputs=PIN_A2)
I'm thinking this could be useful.
Cheers.
PostPosted: Tue Dec 30, 2014 8:47 pm     Reply with quote
not to sure how it could be useful...
..it's a waste of PIC resources( memory) and speed( does unessessary operations( the first directive).
kinda the same as
a=0;
a=1;
coding a=0; is a waste as PIC does that THEN does a=1.
hth
jay
Eugeneo
PostPosted: Tue Dec 30, 2014 9:14 pm     Reply with quote
You're right.
How about this then:
#use fast_io(a)
So you don't have to mess with registers.
PostPosted: Wed Dec 31, 2014 2:16 am     Reply with quote
The second I/O directive overrides the first. Wastes time again, since the compiler will then be setting the port direction every time the port is accessed.
Just either use fast I/O and tris or do the direct access as I showed.
