PIC18F26K80 strange delay_ms() problem
kahnm
PostPosted: Fri Dec 19, 2014 11:10 am     Reply with quote
Processor PIC18F26K80
Compiler Version 4.141
delay_ms(250) seems to work in the following LED blink demo code but delay_ms(500) does not. No blinking occurs.
What's going on?
In other code (not for this processor) I've used more than a byte in delay_ms.
Any help will be greatly appreciated.
//PIC18F26JK80
#include <18F26K80.h>
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES VREGSLEEP_SW             //Ultra low-power regulator is enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES LP                       //Low power osc < 200 khz
#FUSES WDT_NOSLEEP              //Watch Dog Timer, disabled during SLEEP
#FUSES INTRC_IO                  //RA6 & RA7 are IO
#use delay(clock=16000000)
#use FIXED_IO( A_outputs=PIN_A7)
   setup_oscillator(OSC_16MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
      OUTPUT_LOW(PIN_A7);
      OUTPUT_HIGH(PIN_A7);
PostPosted: Fri Dec 19, 2014 11:30 am     Reply with quote
Get rid of the fuse shown in bold below. You are enabling the WDT:
PostPosted: Fri Dec 19, 2014 12:07 pm     Reply with quote
also LP. There should only be one oscillator fuse.
kahnm
PostPosted: Fri Dec 19, 2014 1:09 pm     Reply with quote
Took out the watchdog and that solved it.
Also took out LP.
Thanks a million!
