dsPIC on Explorer16 -- SOLVED
oxo
PostPosted: Fri Dec 05, 2014 2:40 am     Reply with quote
Hi All,
I have dsPIC33EP512MU810 on an Explorer16, and I cant get it to debug.
It compiles, and loads the code, but then I get an error dialog,
"Target program not running. Likely cause is wrong debug pins, or wrong oscillator."
But, I have checked both of these.
Fuses are
#include <33EP512MU810.h>
#device ICD=1
#device ADC=8
#use delay(crystal= 8000000)
#fuses PR_PLL, XT
#fuses NOWDT, NOJTAG
#fuses DEBUG
#fuses ICSP1
Compiler PCWHD, Ver 5.032
PostPosted: Fri Dec 05, 2014 2:54 am     Reply with quote
Start with your oscillator.
You are specifying that you want to run at 8MHz, with an 8MHz crystal. The fuses for this are PR, XT. The PR_PLL combination, can't do 8MHz....
Then obviously, you do have MCLR pulled up?.
oxo
PostPosted: Fri Dec 05, 2014 4:12 am     Reply with quote
Thank TT,
I checked the oscillator with a scope on the processor pins. 8 MHz. Good
Also checked the target connections with a scope on the PGC, PGD and MCLR pins, using CCSLoad diagnostics to flip their states. These work fine.
So, I cut my program down to the minimum.
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#device ICSP=1
//#device ICD=1
#fuses PR, XT
//#fuses DEBUG
//#fuses ICSP1
#use delay(clock= 20000000, crystal=8000000)
#use FIXED_IO( A_outputs=PIN_A7,PIN_A6,PIN_A5,PIN_A4,PIN_A3,PIN_A2,PIN_A1,PIN_A0 )
      output_low(PIN_A0);
      output_high(PIN_A0);
This code loads and runs fine, at the correct on/off periods for the LED in run and load mode.
But if I try and use it in debug mode, or uncomment any of the lines shown, it does not run, and I get the error from my first post.
oxo
PostPosted: Mon Dec 08, 2014 12:56 am     Reply with quote
I think this is solved, but I can't try the solution yet.
It appears that EP processors require an ICD-U64 Revision 3 or later..
PostPosted: Mon Dec 08, 2014 3:43 am     Reply with quote
As a comment, have you got the ETN-29 patch, and the latest firmware. The patch is present in the later unit, and might be the problem. This seems to be the only hardware change on the circuits posted between the rev 194, and 195.
Note the 194 can be upgraded to a 195.
oxo
PostPosted: Mon Dec 08, 2014 3:54 am     Reply with quote
My ICD-U64 is Rev 2, so I believe that's the issue. I have all firmware updates, but Rev 2 is what kills it. Trying to get a rev 3 quickly for tomorrow.
Thanks.
PostPosted: Mon Dec 08, 2014 4:01 am     Reply with quote
Have you tried the ETD#29 patch?.
On some chips this is required, and is standard on the later boards. R61 and R62 have to change from 1KR to 100R.
oxo
PostPosted: Mon Dec 08, 2014 4:06 am     Reply with quote
That patch is for MPLAB, not ICD-U64.
The info about revision numbers came from CCS..
PostPosted: Mon Dec 08, 2014 1:46 pm     Reply with quote
No, it is not for MPLAB, it is for the older ICD3 board. However if you look at the published circuits for the U64, it has the same control circuit. I'd suggest it is very likely that this part is the same.
dyeatman
PostPosted: Mon Dec 08, 2014 2:10 pm     Reply with quote
This page also says it requires a version 3 to debug...
http://www.ccsinfo.com/devices.php?page=icddevices
Google and Forum Search are some of your best tools!!!!
PostPosted: Mon Dec 08, 2014 2:19 pm     Reply with quote
Agreed. But it also says they can modify the earlier versions for $25. If you look at the circuits (Microchip nicely publish them), the only hardware changes are to the resistors in the drive circuit.
oxo
PostPosted: Mon Dec 08, 2014 2:39 pm     Reply with quote
Its late, but I will try that in the morning. Thanks.
PostPosted: Mon Dec 08, 2014 2:53 pm     Reply with quote
Look at the circuits first. The part numbers are not the same on all board versions, so you need to check which yours are.
oxo
PostPosted: Tue Dec 09, 2014 2:05 am     Reply with quote
Can't find the schematics. Do you have a link?
oxo
PostPosted: Tue Dec 09, 2014 5:28 am     Reply with quote
The ICD-U64 Rev 3 arrived, and it all works now.
