freebee
Raspberry B+ i2c PIC 18F4550 Slave problem. |
Posted: Tue Nov 25, 2014 11:21 am |
hi for all,
I am very novice in code and i want just send string from a pic to a raspberry pi. Raspberry b+ is just i2c master and pic just slave.
Code for i2c pic slave:
Code: | #include <18F4550.h>
#device adc=10
#fuses XT, NOWDT, PUT, BROWNOUT, NOLVP
#use delay(clock=20Mhz)
#define PIC_TRIS_B 0b00000011 // Input mode B0 and B1
#use i2c(Slave, Slow, sda=PIN_B0, scl=PIN_B1, address=0x08)
i2c_start();
i2c_write(0x55);
delay_us(500);
The idea is just send a data to raspberry pi.
This code compiles, but no send data. Can somebody help me ?. |
Posted: Tue Nov 25, 2014 11:56 am |
Look at the slave example.
All I2C transactions are initiated by the master. A slave cannot send a start.
The slave has to wait for the master to send a data request, with the correct address, and _then_ load the byte for the reply.
As a comment, have you actually tested your PIC is working?. XT, and 20MHz, are _not_ legal clock settings. |
