PIC16F873 - Changing CCP1 value but not affecting frequency
JeffN
PostPosted: Fri Nov 14, 2014 5:54 pm     Reply with quote
I'm using the Compare function to generate variable frequencies depending to a value read from PortB. I write to CCP1 to establish the default frequency and this works fine. While running I write to CCP1 again to change the freq but no effect. I read the CCP1 reg and output the value to PORTC. The CCP1 value is changing with the PortB reading but the interrupt frequency does not change???
Any ideas why this is possible??
Hopefully,
Jeff
asmboy
PostPosted: Fri Nov 14, 2014 6:07 pm     Reply with quote
post your code after reading:
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
until you do that who wants to play 20 questions??
Very Happy Very Happy Very Happy
JeffN
PostPosted: Mon Nov 17, 2014 11:24 am     Reply with quote
Solved: Faulty regulator not supplying enough supply voltage - erratic behaviour. Thank you.
