TC63 GSM module
Goto page 1, 2  Next
Jim90
TC63 GSM module
PostPosted: Wed Nov 12, 2014 2:49 pm     Reply with quote
I want to create a new project with the use of TC63 gsm module.
My problem is that i don't know if is possible to use TC63 with CCS compiler.
I can't find any resources and i don't know anyone who use this module with CCS so i don't know if this is feasible.
(I am thinking if any restriction exist which i can not see)
PostPosted: Wed Nov 12, 2014 3:12 pm     Reply with quote
You should post a link to the exact module you've got !
From that we'll be able to see how easy it will be to interface to it.
items of concern...
1) power supply. Most(all ?) devices these days are 3 volt units. NONE will directly, correctly interface with a 5 volt PIC, so the easy way is to select a 3 volt PIC. Those like PIC16LFxxx are 3 volt devices, the 'L' is the key here.
2) communications interface. It could be TTL serial( aka 'RR-232), SPI, I2C or propriatory.
3)commands. Typically an 'AT command set' is used,though without seeing the actual datasheet I can't tell.
Bottom line, YES you can use CCS C to use the TC63 module however you'll need to supply us with more information. Undoubtedly someone's posted a program or 2 in the 'code library' here.Before you just 'cut and paste' and complain 'it doesn't work, be sure to create and test a simple 'Hello GSM' test program. It should read some GSM registers, set some options, read back those options. This basic test will confirm the interface is good,hardware correct and gives you a solid base to carry on from.
Cheers
Jay
Jim90
TC63 GSM module
PostPosted: Wed Nov 12, 2014 4:54 pm     Reply with quote
The datasheet is:
http://www.docdroid.net/l2se/tc63i.pdf.html
dyeatman
PostPosted: Wed Nov 12, 2014 5:07 pm     Reply with quote
Google and Forum Search are some of your best tools!!!!
ezflyr
PostPosted: Wed Nov 12, 2014 5:42 pm     Reply with quote
We've already been down this road a million times? Unless the OP can produce a data sheet for the exact hardware he has then this thread is pointless, and will only end in frustration!
There is a high likelihood that the 'TC63' module referred to by the OP is actually the Siemens module mounted to a breakout board that includes some interface circuitry. Unless we have access to exactly what is being used then this thread is hopeless!
Note the raw TC63 requires a fine pitch SMD connector interface, so it's 100% certain that is not what the OP has!
John
Jim90
TC63 GSM module
PostPosted: Wed Nov 12, 2014 5:53 pm     Reply with quote
This is exactly the module which i have.(actually i am thinking to buy)
http://export.farnell.com/cinterion/tc63i/mod-gsm-gprs-quad-band-tcp-ip/dp/1718876
At my last post i upload the document which is given to this site.
Any feedback??
whatdo you think ? (i really need advice)
ezflyr
PostPosted: Wed Nov 12, 2014 6:05 pm     Reply with quote
Sorry, that link opens to a generic Farnell export page, not to anything specific the a GSM module. It may just be my current location (Japan) that is preventing me from viewing it?
John
PostPosted: Wed Nov 12, 2014 6:11 pm     Reply with quote
http://uk.farnell.com/cinterion/tc63i/mod-gsm-gprs-quad-band-tcp-ip/dp/1718876
ezflyr
PostPosted: Wed Nov 12, 2014 6:20 pm     Reply with quote
100% you can make that work with a PIC, but the electrical/mechanical interface challenges will be formidable. Are you prepaired to solder an 80 pin fine pitch connector? Find another module!
John
Ps thanks PCM programmer for the link!
Jim90
TC63 GSM module
PostPosted: Wed Nov 12, 2014 6:25 pm     Reply with quote
Thanks guys.
Except the issue with the soldering, do you think that this module is reliable, easy to program, etc ?
PostPosted: Wed Nov 12, 2014 7:07 pm     Reply with quote
Well I still haven't seen a proper datasheet for it yet...all links lead to 'sales sheets' not hard core data.
As I suspected it's a 3 volt device, so you best use an 'L' version PIC..
Has I2C as well as SPI interfaces, so very easy for a PIC to hookup to it.
reliable ? zero knowledge of the device, again no datasheet....
easy to program, unknown, again NO datasheet...
Knowledge is power....
Jay
PostPosted: Wed Nov 12, 2014 8:17 pm     Reply with quote
It's out there if you search for this:
tc63i_hd_v01100a.pdf
Otherwise you have to signup on their website to get it.
ezflyr
PostPosted: Thu Nov 13, 2014 12:57 am     Reply with quote
Personally, I'd think something like this is a better choice: http://imall.iteadstudio.com/im140318007.html
John
Jim90
TC63 GSM module
PostPosted: Thu Nov 13, 2014 5:03 am     Reply with quote
Why you think is better?
I think TC63I has more features
PostPosted: Thu Nov 13, 2014 6:04 am     Reply with quote
Quite probably.
The point being made, was that this is _well_ documented, and easy to connect to. You could probably have a system talking to this in a couple of hours work on a breadboard. While the TC63I, will involve starting by making a PCB. Then you have 'what extra features are actually going to be of any use'?....
Goto page 1, 2  Next
Page 1 of 2
