Which Endpoint to send CBW in USB Host
Jun
PostPosted: Tue Nov 11, 2014 9:09 pm     Reply with quote
hi,
I am working on USB Host project to read/write mass storage device.
I am confused on which Endpoint to send CBW. As per Bulk-only protocol explain, "The host shall send each CBW, which contains a command block, to the device via the Bulk-Out endpoint."--<Universal Serial Bus Mass Storage Class Bulk-Only Transport>.
For example, the Bulk-out Endpoint of my USB stick is Endpoint2. I send a CBW with Read Capacity command via endpoint2.
I can actually get a ACK for the CBW transfer, but I can't get TRNIF interrupt.
But when I read the Microchip's MLA-- USB Host -MSD-Data logger's code, it use endpoint0 to send the CBW. but endpoint2 buffer.
I am not sure where I got wrong. If we use Endpoint0 to send CBW and receive data, then what is the point to know which one is the bulk-out and bulk-in endpoint?
Thanks for your help.
Jun
