how to interface DC motor with PIC16f877a?
KATHISAIPRATHAPREDDY
PostPosted: Tue Nov 04, 2014 10:07 am     Reply with quote
Is there any special .c file for motor interface. Can we write our own .h file to compile the motor programs?
PostPosted: Tue Nov 04, 2014 12:32 pm     Reply with quote
You need to provide more information:
Do you want to control just run/stop or variable speed?
Do you want forward and reverse?
PostPosted: Tue Nov 04, 2014 1:31 pm     Reply with quote
What kind of motor?
AC
DC
VFD
1PH
3PH
What kind of 'control'
feedback ?
encoder?
RC servo?
protection?
over V, over I, etc.
There's probably 3 or 4 dozen answers needed before a real answer can be acquired.
Jay
gpsmikey
PostPosted: Tue Nov 04, 2014 7:41 pm     Reply with quote
Why does this sound like a homework assignment?
mikey
mikey
PostPosted: Tue Nov 04, 2014 9:47 pm     Reply with quote
Use the LMD18200 H-Bridge chip. Use PWM from the 16F877A to drive it.
Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=40467&start=1
Buy or build a board with the LMD18200 chip on it:
http://www.electrokit.com/en/dc-motor-control-based-on-lmd18200.47375
Use the 16F877A to control it.
i used 16f877a MC to control the DC motor with motor drivers
PostPosted: Thu Nov 06, 2014 6:42 am     Reply with quote
I failed to write a program to control the dc motor to move forward, backward, left, and right. Also i want to control the speed of motor.
My project need to detect the object, and it will act on the object. My program follows like this:
#include <16f877a.h>
#use delay(clock=20M)
#fuses NOWDT,PROTECT,HS
#include <motor.c>
Void main()
unsigned int i, value, temp,gas;
output_high(pin_d2);
output_high(pin_d3);
output_low(pin_d2);
output_low(pin_d3);
output_low(pin_d2);
output_low(pin_d3);
      for(i=0;i<=10;i++)
       set_adc_channel( 0 );
      delay_ms(50);
      value = read_adc();
      temp = value*2.5;
      motor_forward();
      output_low(pin_d2);
      output_low(pin_d7);
      if(input(pin_b0))
      motor_right();
      output_low(pin_d3);
      output_low(pin_d7);
      else if (temp > 50 )
      output_high(pin_d7);
      output_low(pin_d2);
      output_low(pin_d7);
But i have problem while compiling the code in pic c compiler. Can anyone help me? Basically the problem is with motor.c file. Can we write motor.c by our own or somewhere else ?
PostPosted: Thu Nov 06, 2014 7:12 am     Reply with quote
Controlling a motor depends totally on _your_ hardware. Nothing else.
Motor.c, is nothing but functions to turn on the bits needed to control the motor hardware, which depends totally on _your_ design. So if (for instance), you have an H bridge driver as already described, you need to turn on the top FET on one side, and the bottom FET on the other to feed power 'forwards', for 'motor_forwards', and if speed control is wanted feed a suitable signal out of the PWM. The reverse code requires the opposite pattern. This is all 100%, down to _you_, and _your_ hardware. There is no universal solution to motor control, and yes 'of course' you can write the code yourself, but you need to have worked out what you actually need out of the pins, and what dangers there are (remember your driver will also need to handle things like the inductive nature of the motor, and generation when it is spinning, and you turn off). These are all electronic _hardware_ questions, and nothing to do with code. You need to get your hardware working _first_, and then work out what is needed from the PIC to control this.
