(Solved) USB_HID_REQUEST_SET_REPORT implementation
steav
PostPosted: Wed Nov 05, 2014 3:36 am     Reply with quote
Hi!
I'm using CCS PCD v5.030 with PIC24FJ256DA210 (MCP development board).
The CCS HID USB driver is working fine, but I can't get the HID get_report/set_report feature to work.
USB.h - CCS already defined these codes, but didn't implement it.
//HID Class Setup bRequest Codes
#define USB_HID_REQUEST_GET_REPORT     0x01
#define USB_HID_REQUEST_GET_IDLE       0x02
#define USB_HID_REQUEST_GET_PROTOCOL   0x03
#define USB_HID_REQUEST_SET_REPORT     0x09
#define USB_HID_REQUEST_SET_IDLE       0x0A
#define USB_HID_REQUEST_SET_PROTOCOL   0x0B
USB.c - The function which handles these codes is already defined
/* usb_isr_tkn_setup_ClassInterface()
/* Input: usb_ep0_rx_buffer[1] == bRequest
/* Summary: bmRequestType told us it was a Class request.  The only Class this drivers supports is HID.
/*          bRequest says which request.  Only certain requests are valid,
/*          if a non-valid request was made then return with an Wrong-Statue (IDLE)
/* Part of usb_isr_tok_setup_dne()
/* Only compiled if HID_DEVICE is TRUE
#IF USB_HID_DEVICE
void usb_isr_tkn_setup_ClassInterface(void) {
   switch(usb_ep0_rx_buffer[1]) {
    #IF USB_HID_BOOT_PROTOCOL
      case USB_HID_REQUEST_GET_PROTOCOL:  //03
            debug_usb(debug_putc,"GP");
            usb_ep0_tx_buffer[0]=hid_protocol[usb_ep0_rx_buffer[4]];
            usb_request_send_response(1);
    #ENDIF
      case USB_HID_REQUEST_SET_PROTOCOL:  //0b
            debug_usb(debug_putc,"SP");
            hid_protocol[usb_ep0_rx_buffer[4]]=usb_ep0_rx_buffer[2];
            usb_put_0len_0(); //send 0len packet69
    #ENDIF
   #IF USB_HID_IDLE
      case USB_HID_REQUEST_SET_IDLE:   //0a
         #error TODO: if you want to support SET_IDLE, add code here
   #ENDIF
   #IF USB_HID_IDLE
      case USB_HID_REQUEST_GET_IDLE:   //02
         #error TODO: if you want to support GET_IDLE, add code here
   #ENDIF
       case USB_HID_REQUEST_SET_REPORT:
           output_high(P_GREEN);
           // Do something here
       case USB_HID_REQUEST_GET_REPORT:
      default:
            usb_request_stall();
#ENDIF
I added the USB_HID_REQUEST_SET_REPORT and USB_HID_REQUEST_GET_REPORT.
In the moment I write a packet using HIDAPI (http://www.signal11.us/oss/hidapi/), the green led lights up Very Happy
unsigned char buf[65];
res = hid_write(handle, buf, 65);
I also set all HID buffer sizes to 64:
#define USB_MAX_EP0_PACKET_LENGTH   64
#define USB_CONFIG_HID_RX_SIZE   64
#define USB_CONFIG_HID_TX_SIZE   64
Now I just want to receive USB_HID_REQUEST_SET_REPORT 64byte packets of custom data from HIDAPI, using usb_get_packet().
The strange thing is, if I use usb_kbhit() and usb_get_packet(), to check if there are some new packets available, I only get packets from the operation system asking the PIC e.g. for device descriptors, and since I receive them in my main application instead of the CCS HID driver, the USB device is freezing.
Thanks a lot!
PostPosted: Wed Nov 05, 2014 4:44 am     Reply with quote
Look at ex_usb_kbmouse2.c
This uses two HID reports one to handle a mouse, and one a keyboard. Note it is just sent as a packet. No fiddling changing the driver.
Then look at the reception of the LED settings.
Beware that unless you must have 64bytes, if you are using a report ID, then it is faster to keep the total packet <=64bytes, including the ID.
steav
PostPosted: Wed Nov 05, 2014 5:01 am     Reply with quote
Thank you for your answer!
I do it exactly the same way:
void usb_rx_task(void)
   int8 rx_msg[USB_EP1_RX_SIZE];
   if (usb_kbhit(1))
      usb_get_packet(1, rx_msg, sizeof(rx_msg));
Unfortunately, the usb_kbhit(1) triggers on every incoming USB packet, especially on those which should by handled by the HID driver itself. If I use this code above, my USB Prober App (http://touch-base.com/documentation/USBMacProber.htm) doesn't show the string desc. (manufacturer, serial...) anymore and is freezing while waiting for these reply packets. So I decided to extend the HID driver with the code for the case USB_HID_REQUEST_SET_REPORT. I just don't know how to access the payload of a HID set report request (initiated by HIDAPI) within this switch-case.
I didn't change anything else in the driver but the sizes to 64.
As you mentioned, 32bytes of payload for each HID packet are enough for me. I can change that.
steav
PostPosted: Wed Nov 05, 2014 6:14 am     Reply with quote
I found the problem!
The USB driver files where included in incorrect order, overwriting some #define macros. Now it is working as it shound using usb_kbhit(), without the need of adding a USB_HID_REQUEST_SET_REPORT switch-case.
VernonAMiller
PostPosted: Wed Nov 05, 2014 8:07 am     Reply with quote
If it's a mistake you think one of us might make, please let us know the correct order so we can not make it Smile
Thanks!
VAM
steav
PostPosted: Wed Nov 05, 2014 8:18 am     Reply with quote
The correct order is just to include the USB files in the same way as shown as in the examples and NOT to remove #includes within driver files Wink
In my main application, these are the includes, copied from the PICC drivers folder:
Header includes
#include "Driver/USB/usb_desc_hid.h"
#include "Driver/USB/usb.h"
#include "Driver/USB/pic24_usb.h"
Source includes
#include "Driver/USB/usb.c"
VernonAMiller
PostPosted: Wed Nov 05, 2014 8:40 am     Reply with quote
Cool. Thanks!
VAM
PostPosted: Wed Nov 05, 2014 10:01 am     Reply with quote
Well done, and well done for updating (helps others).
