Examine interrupt status
Bieli
PostPosted: Sat Oct 25, 2014 4:09 am     Reply with quote
Hello All,
How can I examine is interrupt is enable or disable?
I use enable_interrupts(INT_TIMER1);, disable_interrupts(INT_TIMER1); to activate or deactivate it but I'd like to check is it on or off.
Regards
Bieli
VernonAMiller
Re: Examine interrupt status
PostPosted: Sat Oct 25, 2014 5:36 am     Reply with quote
Bieli wrote:
Hello All,
Regards
Bieli
You can just look in the proper Interrupt Control (INTCON) register to see if the bit is set. The enable_interrupts() function just sets a bit in one of the INTCON registers, and you can test that same bit to see if the interrupt is enabled.
For example, here is the code that enable_interrupts() generates for Timer0 on a PIC18F2685:
....................     enable_interrupts(INT_TIMER0);
0065C:  BSF    INTCON.T0IE
Read the datasheet for your processor, and maybe look at the code the compiler generates for your PIC for enable_interrupts() and use that as your guide.
VAM
dyeatman
PostPosted: Sat Oct 25, 2014 5:59 am     Reply with quote
Or do it the easy way...
Look on page 56 of the current CCS manual under Interrupts.
There you will find Interrupt_Enabled()
The details are on page 80.
It always helps to read the manual!
Google and Forum Search are some of your best tools
VernonAMiller
PostPosted: Sat Oct 25, 2014 4:11 pm     Reply with quote
DOH! Forgot about that one. That's what I get for answering in a hurry too early in the morning! Smile
VAM
Bieli
PostPosted: Sun Oct 26, 2014 6:40 am     Reply with quote
Thanks for suggestion.
There was no Interrupt_Enabled() function in my help (5.030) but I found
interrupt_active() looks it work same.
Regards
Bieli
dyeatman
PostPosted: Sun Oct 26, 2014 7:14 am     Reply with quote
No, Interrupt_Active checks to see if the Interrupt has been activated (fired)
due to an event. However, along the lines of what VernonAMiller wrote
earlier, you did not say which processor so here is a generic example
#byte CtlReg = getenv("SFR:PIE1") // get Timer 1 Interrupt Enable register
#bit Tmr1IEn = CtlReg.0 // get the Enable bit
<or, go after the bit directly.... >
#bit TMR1IEn=GETENV("BIT:TMR1IE")
<then>
if (Tmr1IEn) ....... // now we can test it
**** Remember, you have to read the datasheet for your processor
to get the correct bit/register names.
