Controller doesn`t start without programmer?!
stoyanoff
PostPosted: Sat Oct 18, 2014 7:43 am     Reply with quote
Greetings. I`m using MPlab 8.91, CCS v5.025 and PIC18F67K22.
When I load the program, the microcontroller doesn`t start if the PICkit 3 programmer is not in the ICSP. It`s not in debug mode. When I turn on the power, I just have to put the PICkit into the connector and the controller starts. Otherwise it doesn`t.
Here are my fuses:
#include <18F67K22.h>
#fuses XT,NOWDT
#use delay(clock=10M)
Can you tell where to look for the problem?!
Thanks!
PostPosted: Sat Oct 18, 2014 7:51 am     Reply with quote
um....
how have you configured the _MCLR pin ??
I know silly to ask but I've been down THAT road before.....
are you powering the PIC from the PICkit instead of 'local' power?
I've done THAT as well.....
Jay
asmallri
Re: Controller doesn`t start without programmer?!
PostPosted: Sat Oct 18, 2014 8:09 am     Reply with quote
Here are my fuses:
#fuses XT,NOWDT
Thanks!
I do not use that specific PIC but the most common flaw with the PIC18F is the LVP where the fuse setting to enable LVP by default.
Try adding the fuse NOLVP
Regards, Andrew
stoyanoff
PostPosted: Sat Oct 18, 2014 8:24 am     Reply with quote
I think this NOLVP helped!
Thanks!
PostPosted: Sat Oct 18, 2014 8:53 am     Reply with quote
#fuses XT,NOWDT
That's the wrong oscillator fuse for 10 MHz. In one of your old posts
you are using the HSH fuse (though it should be HSM for 10 MHz):
http://www.ccsinfo.com/forum/viewtopic.php?t=52538
Why did you change it to XT ?
18F67K22 doesn't support LVP mode. There is no LVP config bit.
There is no NOLVP fuse. Using it causes the build to fail:
Executing: "C:\Program files\Picc\CCSC.exe" +FH "PCH_Test.c" +DF +LY -T -A +M -Z +Y=9 +EA #__18F67K22=TRUE
*** Error 111 "PCH_Test.c" Line 2(7,23): Unknown keyword in #FUSES "NOLVP"
1 Errors, 0 Warnings.
Build Failed.
This was tested with vs. 5.025.
18F67K22 data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/39960d.pdf
What are you doing ?
Do you have MPLAB configured for the correct PIC that you are using ?
