Echo in Rs485
Fabri
Echo in Rs485
PostPosted: Fri Oct 10, 2014 8:46 am     Reply with quote
Hi to All,
I want to drive RS485 modem with AT command. When I send command in received buffer I have also echo of tx instead only answer from modem.
This is example:
*                                 main.c                                    *
#define debug
#include "18F46K22.h"
#include "DEF452.C"
//_______________________________________________________________________Setup
#if defined(debug)
   #fuses HSM,NOPBADEN,DEBUG,NOWDT,NOPROTECT,NOPUT,NOBROWNOUT,CPD,NOLVP,NODEBUG,NOCPB,STVREN,NOPLLEN,NOFCMEN
   #device ADC=10 icd=true
   #else
   #fuses HSM,NOPBADEN,NODEBUG,WDT,PROTECT,PUT,CPD,NOLVP,BORV29,CPB,STVREN,NOPLLEN,NOFCMEN
   #device  ADC=10
   #endif
#device *=16 ADC=10
//______________________________________________________________Abilita Delay
#use delay(clock=16000000,RESTART_WDT)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,enable=PIN_C5,restart_wdt,errors,stream=MODEM)
char buffer_rx[200];
int counter_rx;
#USE FAST_IO(A)
#USE FAST_IO(B)
#USE FAST_IO(C)
#define true 1
#define false 0
#INT_RDA
void SerialInt()
   buffer_rx[counter_rx]=fgetc(MODEM);       // Gets chars from uart
   counter_rx++;                                 // Increment counter
      if(counter_rx>=200)
         counter_rx=0;                     // Circle Buffer
void main() {
set_tris_a(0b00000001);
set_tris_b(0b01000000);
set_tris_c(0b10000000);
set_tris_d(0xFF);
set_tris_e(0x00);
PORTA=0;
PORTB=0b11000000;
PORTC=0;
PORTD=0;
PORTE=0;
setup_timer_0(RTCC_DIV_64|RTCC_INTERNAL|RTCC_8_BIT);
enable_interrupts(INT_RDA);
    /* Setup iniziale inverter */
    while(true){
   restart_wdt();
   buffer_rx="";
   counter_rx=0;
   printf("AT\r");                     // Send Attention Command
    delay_ms(2000);
   delay_cycles(1);
I tried to change manually enable of RS485 driver without solve problem.
Can somebody help me to solve this problem ?
ezflyr
PostPosted: Fri Oct 10, 2014 10:51 am     Reply with quote
Are you sure it's not the modem echoing the Rx data? Most AT command 'modems' will do this by default, but this feature can be disabled. Here is how I disable command echoing on an ADH8066 GSM modem based project:
   // Here we turn OFF AT command echoing from the ADH8066 module!
   fprintf(ADH8066, "ATE0\r");
John
Fabri
PostPosted: Fri Oct 10, 2014 11:10 am     Reply with quote
Thanks John,
After now "ATE0\r" I don't receive "AT" echo.
I didn't think about it because with PC and terminal I haven't echo. I can't realize it why.
Anyway I solved it !
Regards,
Fabri
PostPosted: Fri Oct 10, 2014 12:44 pm     Reply with quote
Ok maybe I'm blind from welding today but just where do you actually print out the received data from the modem ??
Fabri
PostPosted: Fri Oct 10, 2014 1:04 pm     Reply with quote
Dear temtronic,
This is only for test and I use ICD3 in debug mode. I don't printout received data. I only watch received buffer in MPLAB.
