how to work with byte as bit array?
40inD
PostPosted: Mon Oct 06, 2014 8:06 am     Reply with quote
I need to sent to function a byte as argument, but inside the function i need to work with this byte like this:
byte.bit or byte[bit]
is it possible?
i.e.
output_bit(PIN_A2, byte[2]); // 3th bit of byte
PostPosted: Mon Oct 06, 2014 9:09 am     Reply with quote
union
40inD
PostPosted: Tue Oct 07, 2014 1:37 am     Reply with quote
solved thru bit_test
void setcode (byte cod)
output_bit(PIN_A2, bit_test(cod,2));
output_bit(PIN_A4, bit_test(cod,4));
output_bit(PIN_A5, bit_test(cod,5));
PostPosted: Tue Oct 07, 2014 8:51 am     Reply with quote
you might reconsider the very good advice from MR. "T" in the previous post, especially after you look in the .LST file to see what your code generates..
