PIC24FJ64GA306 oscillator setup
gaugeguy
PostPosted: Wed Oct 01, 2014 11:46 am     Reply with quote
I am trying to switch between the primary crystal oscillator and the secondary oscillator for a lower power operation mode. I have done this frequently with PIC18 processors and I am trying to do the same on the PIC24.
The built-in function seems to not be accepting the OSC_SECONDARY option, which was copied from the processor include file.
I have sent a report to CCS but thought someone here may have some insight if I am missing something obvious.
#include <24FJ64GA306.h>
#device ADC=12
#build(STACK=512)
#FUSES WINDIS                   //Watch Dog Timer in non-Window mode
#FUSES NOLVR                    //Low Voltage Regulator Disabled
#FUSES NOJTAG                   //JTAG disabled
#FUSES NOIOL1WAY                //Allows multiple reconfigurations of peripheral pins
#FUSES NOOSCIO                  //OSC2 is clock output
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES VREFNORM_CVREFNORM       //VREF and CVREF are mapped to their default pins
#FUSES WPFP                     //Write/Erase Protect Page Start/End Location, set to last page or use WPFP=x to set page
#FUSES VBATBOR                  //VBAT BOR Enabled
#FUSES SOSC_SEL                 //SOSC circuit selected
#FUSES WDTWIN_25%               //Watchdog Window is 25% of WDT period
#FUSES WPDIS                    //All Flash memory may be erased or written
#FUSES NOWPCFG                  //Configuration Words page is not erase/write-protected
#FUSES WPEND                    //Flash pages WPFP to Configuration Words page are write/erase protected
#FUSES DSWDT_25DAYS             //DSWDT uses 1:68719476736 Postscale (25.7Days)
#FUSES DSWDTCK_LPRC             //DSWDT uses LPRC as reference clock
#FUSES DSBOR                    //BOR enabled in Deep Sleep
#FUSES DSWDT                    //Deep Sleep Watchdog Timer enabled
#FUSES DS_SW                    //Deep Sleep is controlled by the register bit DSEN
#device ICSP=1
#use delay(clock=32Mhz,crystal=8MHz)
void  main()
   delay_ms(2000);
   setup_oscillator(OSC_SECONDARY);       // error message Option invalid :: No Internal Osc
   delay_ms(2);
   setup_oscillator(OSC_INTERNAL,31000);
   delay_ms(2);
   setup_oscillator(OSC_CRYSTAL,32000000,8000000);
Compiler version is 5.024
gaugeguy
PostPosted: Wed Oct 01, 2014 2:17 pm     Reply with quote
I heard back from CCS support and
setup_oscillator(OSC_SECONDARY, 32768, 32768);
makes the compiler happy.
jeremiah
PostPosted: Wed Oct 01, 2014 3:46 pm     Reply with quote
One thing you should be careful of going forward is that you are not specifying your primary oscillator's fuses. If you are lucky, the compiler will pick the right ones, but I have been bitten by this before. There are 2 fuses of interest:
#FUSES PR_PLL //tells the PIC the default clock source is an external clock/osc with PLL
#FUSES HS //tells the PIC to use the high speed oscillator circuit.
On the second one, I didn't have the Datasheet in front of me, so I assumed 8MHz is an HS type circuit. If it is not, then it would be
#FUSES PR_PLL
#FUSES XT
while you might be ok as is with the defaults, it is always good to specify.
