LCD 1601A doesnt run
rikotech8
PostPosted: Sat Sep 20, 2014 4:36 am     Reply with quote
Hello folks.
I have a board that I use to be able to run, but now I face some troubles.
It's about LCD 1601A isn't running.
I checked the connections many times, but found nothing disturbing.
Here is the code:
#include <16f1508.h>
#FUSES INTRC_IO, NOMCLR, NOWDT, PUT, PROTECT, NOBROWNOUT, NOIESO, NOFCMEN, NOWRT, NOLPBOR, NODEBUG, NOLVP
#use delay (INTERNAL = 16M)
#define INC_BUTT     PIN_A5
#define DEC_BUTT     PIN_A4
#define ENTER_BUTT   PIN_C5
#define LED_R        PIN_C3
#define LED_G        PIN_C4
#define RELAY        PIN_C6
#define T1           PIN_C7
#define T2           PIN_B7
#define LCD_DB4   PIN_B4
#define LCD_DB5   PIN_B5
#define LCD_DB6   PIN_B6
#define LCD_DB7   PIN_A2
#define LCD_E     PIN_C2
#define LCD_RS    PIN_C0
#define LCD_RW    PIN_C1
#include <lcd.c>
void chip_init (void);
chip_init();
lcd_gotoxy(1, 1);
printf(lcd_putc,"Wellcome...");
   while (TRUE)
      output_toggle(LED_G);
      delay_ms(50);
   setup_wdt (WDT_OFF);
   setup_spi (SPI_DISABLED );
   setup_dac (DAC_OFF);
   setup_oscillator (OSC_16MHZ);
I checked the pulses on the led and the timing is OK exact 100mS period.
But I don't see the message Wellcome... on the screen. I scoped the R/W pin and it never goes low. It should be low in writing mode, isn't it? May be some peripherals weren't disabled correctly/at all?
Some help would be much appreciated!
A person who never made a mistake never tried anything new.
PostPosted: Sat Sep 20, 2014 5:01 am     Reply with quote
It'll only pulse low for a tiny period. You might simply not be seeing it.
This depends a lot on the abilities of your scope.
You should change some settings:
#define LCD_TYPE 1 //it defaults to 2 lines
#define LCD_LINE_LENGTH 16 //it defaults to 20 characters
Try turning off the PWM.
Then simply do the toggle a line test, on the R/W pin. You need to get this working before trying to actually talk to the LCD.
PostPosted: Sat Sep 20, 2014 7:02 am     Reply with quote
You probably have to disable the comparators as well, and maybe the NCO.
They use pin RC1 as well.
For some reason most PICs 'default' to enabling the comparators.
also.... you normally do not use the 'protect' fuse until the product is ready to go 'out the door' for sale.Has nothing to do with your problem, just an observation.
hth
jay
PostPosted: Sat Sep 20, 2014 10:45 am     Reply with quote
1. Where does the lcd.c file come from ? Is it the lcd.c driver file
that comes with the CCS compiler ? Is it this one:
c:\program files\picc\drivers\lcd.c
Or is it a file that you found on the forum or the net ? If so, post a link to it.
2. What's your CCS compiler version ?
3. LCD 1601A would likely be a 16x1 lcd. The memory map for this
type of lcd has two different styles. One type is a normal incrementing
memory address across the display. The other type has a break in the
middle and re-starts with an offset address. Can you post a link to the
data sheet which shows the Data ram address map for the lcd ?
4. There is a 16x1 Flex driver in the Code Library:
http://www.ccsinfo.com/forum/viewtopic.php?t=30964
If your LCD has the address offset for the 2nd half of the characters,
you should use the 16x1 flex driver.
rikotech8
PostPosted: Sat Sep 20, 2014 1:04 pm     Reply with quote
Thank you all.
I changed the code and the display so, to exclude the possibility of faulty LCD unit or corrupted driver. No success though.
The display I am using now is WH2002A, and the driver to flex_lcd.c.
I am sure the display works because I ran it on another board using 18F4620.
No problems there. But when I try with 16F1508 nothing good happens.
I modified my code according to your suggestions.
Here is the new code that suppose to work, but doesn't.
#FUSES INTRC_IO, NOMCLR, NOWDT, PUT, NOBROWNOUT, NOIESO, NOFCMEN, NOWRT, NOLPBOR, NODEBUG, NOLVP
#use delay (internal = 16M)
#define LED       PIN_B6
#include <flex_lcd.c>
chip_init();
printf(lcd_putc, "\fHello Riko!");
   while (TRUE)
      output_toggle(led);
   setup_vref(VREF_OFF);
   SETUP_CWG(0,0,0,0);
   setup_nco(0,0);
   SETUP_CLC1(CLC_DISABLED);
   SETUP_CLC2(CLC_DISABLED);
   SETUP_CLC3(CLC_DISABLED);
   SETUP_CLC4(CLC_DISABLED);
   SETUP_PWM1(PWM_DISABLED);
   SETUP_PWM2(PWM_DISABLED);
   SETUP_PWM3(PWM_DISABLED);
   output_high(led);
   output_low(led);
And here is the flex_lcd.c, I altered the pins so!
https://drive.google.com/file/d/0B5Y7MPFIDn9dZ1oxb0c0WWt1MDQ/edit?usp=sharing
Compiler version: (PCB --- PCD) 5.025
Using the standard lcd.c driver this code stops running at lcd_init(); and never enters the infinite loop. Therefore I replaced it with the alternative one (flex_lcd.c). Now it goes into the infinite loop and led is blinking, but nothing appears on the screen. I keep trying workaround this sh*t.
Thank you again!
PostPosted: Sat Sep 20, 2014 1:51 pm     Reply with quote
#define LCD_DB4 PIN_C4
#define LCD_DB5 PIN_C5
#define LCD_DB6 PIN_C6
#define LCD_DB7 PIN_C7
Have you checked all these LCD pins for signal activity with an oscilloscope ?
You could reduce the 500ms delay in your while() loop so it writes to the
lcd more often. Then you could see activity more easily. Check it at the
LCD pins, not the PIC pins.
PostPosted: Sat Sep 20, 2014 3:48 pm     Reply with quote
This code works with LCD1602 (essentially same display as 1601A) using
16F1507 or the 16F1509 which are the same chip with different
amounts of memory.
If this code doesn't work with 1601 you have a wiring problem or display
(contrast setting?) problem.
Flex_LCD Settings
   #define LCD_DB4   PIN_c4
   #define LCD_DB5   PIN_c5
   #define LCD_DB6   PIN_c6
   #define LCD_DB7   PIN_c7
   #define LCD_E     PIN_c2
   #define LCD_RS    PIN_c0
   #define LCD_RW    PIN_c1  // NOT USED-TIE DISPLAY R/W to GND!!!
//#define USE_LCD_RW   1     // Be sure to comment this out in Flex_LCD
Test Program:
#include <16F1507.H>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock = 16MHZ)
setup_adc_ports(no_analogs);
lcd_init();  // Always call this first.
delay_ms(450);
lcd_putc("\fHello World\n");
lcd_putc("Line Number 2");
      output_toggle(Pin_C3);
rikotech8
PostPosted: Sun Sep 21, 2014 7:46 am     Reply with quote
I cant believe I didn't spot this: Embarassed
Pin definition into a standard lcd.c:
#define LCD_ENABLE_PIN  PIN_B4
#define LCD_RS_PIN      PIN_B6
#define LCD_RW_PIN      PIN_B5
#define LCD_DATA4       PIN_B7
#define LCD_DATA5       PIN_C7
#define LCD_DATA6       PIN_C6
#define LCD_DATA7       PIN_C3
Pin definition into flex_lcd.c:
#define LCD_DB4   PIN_B7
#define LCD_DB5   PIN_C7
#define LCD_DB7   PIN_C3
#define LCD_E     PIN_B4
#define LCD_RS    PIN_B6
#define LCD_RW    PIN_B5
The assigned names for the pins are totally different!
I messed up both. Using definition from one into another and vice versa.
It definitely works now. Thank you all guys !
PostPosted: Sun Sep 21, 2014 8:01 am     Reply with quote
When using 'drivers', I found out decades ago to always make a COPY the original driver ! IE copy 'flex_LCD.C' to 'my_flex_LCD.c'. Make any and ALL changes to YOUR copy, that way you'll always have the original to compare code to.
You can also insert 'conditional' code in the driver( CCS does this) that IF you don't assign variables THEN the default values are assigned.
In any case you should NEVER modify the original drivers.
hth
jay
rikotech8
PostPosted: Sun Sep 21, 2014 10:29 am     Reply with quote
Thank you for the advice, but I haven't change the original version of lcd.c which is the default driver coming along the compiler installation. I only changed the pin assignment into a flex_lcd.c, but it is necessary in order to fit the board requirements. So what do you mean by this:
PostPosted: Sun Sep 21, 2014 11:51 am     Reply with quote
It's always best to copy the original and make ANY changes to YOUR copy. It's too easy to delete a line even one word or character and wonder why 'it worked before'!!
Even simply mistyping(easy with fat fingers or a nerve damaged one...) say an 's' for an 'a' can be very bad. Sure it compiles fine...BUT... doesn't run as expected !!
hth
jay
rikotech8
PostPosted: Sun Sep 21, 2014 1:32 pm     Reply with quote
Yes, I agree. Although my fingers are tiny Smile
