Tachometer
Ruby
Tachometer
PostPosted: Tue Sep 02, 2014 4:53 pm     Reply with quote
Hi guys. I am trying to build a tachometer by pic16f877a with IR sensor.
I think i have trouble with interrupts. Timer stops in the middle...
This is the code i wrote.
Thanks.
#include <16f877a.h>
#fuses hs,nowrt,nowdt,nodebug,brownout,nolvp,nocpd,put,noprotect
#use delay (clock=20000000)
#use rs232(baud=2400, xmit=PIN_C6, rcv=PIN_C7, bits=8, parity=N, errors)
#define LCD_ENABLE_PIN  PIN_B0            //#define use_portb_lcd TRUE
#define LCD_RS_PIN      PIN_B1
#define LCD_RW_PIN      PIN_B2
#define LCD_DATA4       PIN_B4
#define LCD_DATA5       PIN_B5
#define LCD_DATA6       PIN_B6
#define LCD_DATA7       PIN_B7
#include <lcd.c>     // For LCD and has to be after #use delay()
unsigned int16 i=0,t1=0,t2=0;
unsigned int x=0,y=0,t=0;
float32 pulse_width=0;
#int_TIMER1
void one_minute()
   ++i;
   if (i==600) // 60 sec.
      output_toggle(PIN_D1);
      t=0.1*i;
      x=1;
   set_timer1(3035);
void main ()
set_tris_a(0xff);
set_tris_d(0x00);
output_d(0x00);
lcd_init();
printf(lcd_putc,"\fREADY");
printf(lcd_putc,"\nWAITING...");
setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_8 );
set_timer1(3035);                   //========> 1/(20.000.000)*8*4(65535-3035)=0.1 sec.
enable_interrupts(int_timer1);
while (TRUE)
   if (input (pin_A4) && y==0 )
      while (input (pin_A4));
      t1=get_timer1();
      while (!input (pin_A4));
      t2=get_timer1();
      setup_timer_1(T1_DISABLED);
      printf(lcd_putc,"\fCalculating...");
      pulse_width=(0.1*(t1-t2)/(65535-3035))+t;
      printf(lcd_putc,"\fPulse width \n%f seconds",pulse_width);
      y=1;
   if (x==1)
      printf(lcd_putc,"\fTimer Stopped in \n%u seconds",t);
      x=0;
PostPosted: Wed Sep 03, 2014 12:49 am     Reply with quote
Without even looking at the main:
1) i==600 - what then sets i back to 0?.
2) float maths in the interrupt - don't do this. Multiple problems:
First interrupts will be disabled in float multiplies in the main.
Second it takes an age.
Third it is large.
Avoid float maths in anything if you can.
Think about it. Just have an int16 or int32, that is in 0.1 sec 'counts'. Then use %l5.1w in the printf, which will display this as xxx.x seconds. No need to ever involve float. Code will be smaller, faster, and more reliable (fp suffers from routing errors, which integers don't have...).
I didn't look further.
Ruby
PostPosted: Wed Sep 03, 2014 2:23 am     Reply with quote
Thanks for reply.
I have changed the code but now counter goes up not only high to low but also low to high.
unsigned int16 i=0;
unsigned int x=0;
#int_TIMER0
void one_minute()
      ++i;
      x=1;
      set_timer0(255);
void main ()
set_tris_a(0xff);
set_tris_d(0x00);
output_d(0x00);
lcd_init();
setup_timer_0 (RTCC_DIV_2|RTCC_EXT_H_TO_L);
set_timer0(255);
enable_interrupts(int_timer0);
while (TRUE)
   if (x==1 )
      printf(lcd_putc,"\fRPM %Lu",i);
      set_timer0(255);
      x=0;
PostPosted: Wed Sep 03, 2014 2:48 am     Reply with quote
It'll trigger almost instantly....
Timer0, is an 8bit timer. Counts to 256. You are setting it to 255, so it'll trigger just two edges later.....
Mike Walne
PostPosted: Wed Sep 03, 2014 10:34 am     Reply with quote
Please explain EXACTLY how you are trying to achieve a display of RPM.
I can't understand your code at all.
Mike
Ruby
PostPosted: Wed Sep 03, 2014 1:02 pm     Reply with quote
Hi. This is only the first part i wrote. I want to calculate time between two pulses. But the problem is timer interrupts also when it goes low to high.
gpsmikey
PostPosted: Wed Sep 03, 2014 1:24 pm     Reply with quote
While not your current problem, I would give serious consideration to looking at at least 10 pulses (and then applying some form of averaging) or you are more than likely to get numbers that jump all over the place and not be readable. If you are looking at a fan for example with IR and the blades are not symmetrically placed, you will get strange results.
mikey
mikey
Mike Walne
PostPosted: Wed Sep 03, 2014 3:54 pm     Reply with quote
So, what EXACTLY were you trying to do.
To me, your code bears no relation to any of your explanations.
We can better help when you provide more information.
Mike
Ruby
PostPosted: Thu Sep 04, 2014 12:11 pm     Reply with quote
Ok. I have two options for diy tachometer.
1) Calculate time between two pulses
2) Calculate how many pulses in a minute.
I tried the first one. Without calculating time.
Ps: Do I have to use ccp?
Mike Walne
PostPosted: Thu Sep 04, 2014 1:45 pm     Reply with quote
OK. Let's be serious.
Tell us:-
1) What kind of pulses you are trying to measure.
2) The expected frequency range of your pulses.
Maybe then we can start to do sensible design.
Mike
Ruby
PostPosted: Sat Sep 06, 2014 9:30 am     Reply with quote
Poblem solved.
I change two things.
1)setup_timer_0 (RTCC_DIV_2|RTCC_EXT_H_TO_L);  ==> DIV_1
2)The most important ; my sensor has two outputs. Analog and digital. Pic was connected to digital so I swaped it , it works perfect.
Now I did counter but when motor runs fast sensor can't catch the black spot.
And how can I calculate the time between two pulses?
