CWG module 12F1501
mvanvliet
CWG module 12F1501
PostPosted: Mon Sep 01, 2014 6:15 am     Reply with quote
I'm trying to generate a PWM with negative death time (overlap) with the CWG module, but it won't be working.
First problem is that the invert function doesn't work, with this code I have an PWM signal on channel A and B with a duty cycle of 25%, but inverting one of the channels won't change anything on the oscillscope. Has anyone an idea what went wrong?
Compiler version: 5.026
#include <12F1501.h>
#device ADC=8
#FUSES PROTECT
#FUSES NOMCLR
#FUSES NOPUT
#FUSES INTRC_IO
#use delay(internal=8000000)
setup_oscillator(OSC_8MHz);
setup_comparator(NC_NC);
setup_DAC(DAC_OFF);
setup_vref(VREF_OFF);
setup_adc_ports(ADC_OFF);
// Built-in A/D setup function TAD is 2µSec
setup_timer_0(T0_internal|T0_DIV_256);
setup_timer_2(T2_DIV_BY_1,255,1);
setup_CWG(CWG_ENABLED|CWG_INPUT_PWM1|CWG_INPUT_PWM3|CWG_A_INVERTED|CWG_CWG1B_A4|CWG_CWG1A_A2|CWG_CLOCK_HFINTOSC, CWG_NO_AUTO_SHUTDOWN, 512, 512);
setup_PWM1(PWM_enabled|PWM_output);
setup_PWM3(PWM_enabled|PWM_output);
set_PWM1_Duty(255);
set_PWM3_Duty(255);
PostPosted: Mon Sep 01, 2014 7:52 am     Reply with quote
I don't use that PIC but....
old school debugging...
I'd dump out the listing and be sure the compiler's setting the right bits in
the correct registers....
compare what it's listed vs. what the PIC datasheet says.
good news is , there ain't a lot of code to look at !!
hth
jay
PostPosted: Mon Sep 01, 2014 8:31 am     Reply with quote
First problem, would seem to be attempting to select two PWM sources. The CWG, works from _one_ source.
Then you then program a rising edge deadband, and a falling edge deadband on this one signal. The maximum counts for each, are 64 clocks - not 512....
Then you are currently selecting basically full on for the PWM (no time for the deadband signal). 255*4 = 1020 - you need to cast the 255 to a 'long', to give 25% duty.
You dont really want the PWM output enabled, since the CWG becomes the output from it.
The single PWM, should then generate two signals on A2, and A4, that are complementary, with small deadband delays on the rising and falling edges.
I'd expect something like:
#device ADC=8
#FUSES NOMCLR
#FUSES NOPUT
#FUSES INTRC_IO
  setup_DAC(DAC_OFF);
  setup_CWG(CWG_ENABLED|CWG_INPUT_PWM1|CWG_CWG1B_A4|CWG_CWG1A_A2|CWG_CLOCK_FOSC|CWG_A_INVERTED, CWG_NO_AUTO_SHUTDOWN, 10, 10);
  setup_PWM1(PWM_enabled);
  set_PWM1_Duty(512L); //50% test
     delay_cycles(1);
No guarantees.....
Generally don't 'protect' when developing, on some chips this results in unnecessary erase cycles, reducing the life of the chip.
mvanvliet
PostPosted: Wed Sep 03, 2014 2:39 am     Reply with quote
Dear Ttelmah and temtronic,
thank you for looking at my code. Unfortunately with the suggested code from Ttelmah there is no PWM output at all. I've added: output_low(PIN_A2); and output_low(PIN_A4); because on the oscilloscope it seems that PIN_A2 wasn't set as an output pin and floating. Unfortunately it doesn't matter for PWM output. I've attached the assembly of the .lst file, I can't read asm so for me it's hard to understand what the compiler is doing.
.................... setup_CWG(CWG_ENABLED|CWG_INPUT_PWM1|CWG_CWG1B_A4|CWG_CWG1A_A2|CWG_CLOCK_FOSC|CWG_B_INVERTED, CWG_NO_AUTO_SHUTDOWN, 10, 10);
0029:  MOVLW  90
002A:  MOVLB  0D
002B:  MOVWF  13
002C:  MOVLW  02
002D:  MOVWF  14
002E:  CLRF   15
002F:  MOVLW  0A
0030:  MOVWF  11
0031:  MOVWF  12
mvanvliet
PostPosted: Wed Sep 03, 2014 6:04 am     Reply with quote
I found the right way to get an PWM with negative death time:
setup_CWG(CWG_ENABLED|CWG_OUTPUT_A|CWG_OUTPUT_B|CWG_INPUT_PWM1|CWG_CWG1B_A4|CWG_CWG1A_A2|CWG_CLOCK_FOSC|CWG_A_INVERTED|CWG_B_INVERTED, CWG_NO_AUTO_SHUTDOWN, 10, 10);
PostPosted: Wed Sep 03, 2014 6:54 am     Reply with quote
Ah ha. Output enables... Smile
You could omit the two inverted statements. I thought that might be the case, since the default is for the two outputs to be 'complementary'. Currently you are inverting both bits, which is possibly a bit pointless.
mvanvliet
PostPosted: Wed Sep 03, 2014 7:00 am     Reply with quote
No, I need to invert both channels to get an negative death time, without inverting I will get an positive death time. At this moment I have 2 complement PWM outputs with a duty cycle of about 56% (with death time on 63 and 63 and duty cycle of PWM to 50%).
PostPosted: Wed Sep 03, 2014 8:18 am     Reply with quote
Try it and see.
mvanvliet
PostPosted: Wed Sep 03, 2014 8:46 am     Reply with quote
Yes I tried it and they must be both inverted.
PostPosted: Wed Sep 03, 2014 9:08 am     Reply with quote
Shouldn't be the case.
What is the 'off' delay, should become the 'on' delay, and the 'on', should become the 'off'.
With the two delays the same, and 50:50, it should basically be indistinguishable.
Interesting. Will have to look at what they are programming.
mvanvliet
PostPosted: Thu Sep 04, 2014 1:10 am     Reply with quote
I put the PWM value on 512L, so that's 50% duty cycle. When I adjust a death time of 63,63 the duty cycle will be about 43% with positive death time on the rising and falling edge, because I need negative death time I invert both channels and after that the positive duty cycle is 56% with overlapping PWM signals.
I don't know of negative death time is correct english, what I exactly mean is that the rising edge is overlapping and the falling edge is overlapping. Maybe you think I mean only on the falling edge, but it must be on both edges.
setup_CWG(CWG_ENABLED|CWG_OUTPUT_A|CWG_OUTPUT_B|CWG_INPUT_PWM1|CWG_CWG1B_A4|CWG_CWG1A_A2|CWG_CLOCK_HFINTOSC|CWG_A_INVERTED|CWG_B_INVERTED, CWG_NO_AUTO_SHUTDOWN, 63, 63);
