how to run program after first program
nailuy
PostPosted: Mon Sep 01, 2014 12:40 pm     Reply with quote
Hy
I want to run second program after first:
example
#int_CCP1
void ABCD()
//do something
if (a>1){/*do something*/;}
else {EFGH();}
void EFGH()
//do something
I receive undefined identifier error -- EFGH
Can somebody help me to make it work?
Best regards.
PostPosted: Mon Sep 01, 2014 1:16 pm     Reply with quote
Read about function prototypes.
http://coder-tronics.com/wp-content/uploads/2014/02/Function-breakdown.png
nailuy
PostPosted: Tue Sep 02, 2014 1:04 pm     Reply with quote
Thank you.
I found solution
void EFGH();   // function declaration
void ABCD()
else {EFGH();}
void EFGH()    // function definition
This case may close.
Best regards.
ezflyr
PostPosted: Tue Sep 02, 2014 1:20 pm     Reply with quote
Another solution would be to simply move the EFGH() function above the ABCD() function. During compile, the EFGH() reference would have already be resolved by the compiler, so the 'Unidentified Error' problem would not be an issue. IOW, it's possible to structure a 'C' program entirely without 'Function Prototypes', but some may consider that poor form? Your mileage may vary!
John
