deenadayalan
| port A using for input in pic18f4431 |
Posted: Thu Aug 28, 2014 11:40 pm |
I am using pic18f4431, connected lcd in port D, leds connected in port B, switches connected in port A and E. Program is working well but when the switch is closed my controller goes to reset and restarts.
| Code: | #include <18F4431.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
//#FUSES BROWNOUT //Reset when brownout detected
//#FUSES BORV27 //Brownout reset at 2.7V
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWINEN //WDT Timer Window Disabled
#FUSES T1LOWPOWER //Timer1 low power operation when in sleep
#FUSES HPOL_HIGH //High-Side Transistors Polarity is Active-High (PWM 1,3,5 and 7)
//PWM module high side output pins have active high output polarity
#FUSES LPOL_HIGH //Low-Side Transistors Polarity is Active-High (PWM 0,2,4 and 6)
//PWM module low side output pins have active high output polar
#FUSES PWMPIN //PWM outputs disabled upon Reset
#FUSES FLTAC1 //FLTA input is multiplexed with RC1
#FUSES SSP_RC //SCK/SCL=RC5, SDA/SDI=RC4, SDO=RC7
//#FUSES PWM4B5 //PWM4 output is multiplexed on RB5
//#FUSES EXCLKC3 //TMR0/T5CKI external clock input is muliplexed with RC3
//#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8) |
i am using this header file, same program worked successfully in pic16f877a i need more ROM so i selected pic18f4431 pls help me pls.......... |
Posted: Fri Aug 29, 2014 12:37 am |
Critical fuse to change before anything else, is LVP change to NOLVP.
LVP, is _only_ used when using a low voltage programmer. All normal programmers are _not_ low voltage. With this fuse enabled, B5, can no longer be used for normal I/O, and if you put a signal on this pin, the chip will reset (at the least).
You really should have PUT when using a crystal. That is the whole 'point' of this fuse, to allow the crystal oscillator time to start.
Understand something else. Removing a fuse doesn't necessarily turn the feature 'off'. It depends what the default 'un-programmed' state is. So for example, your chip actually has 'BROWNOUT' enabled, since this is the default state. If you don't want this, you need to select the 'NOBROWNOUT' fuse setting. Just remming out the BROWNOUT fuse, and the voltage, leaves the chip set to enable brownout, at 2v.
You also have PWMPIN selected, which means that most of the portB pins are connected to the PWM controller on boot. You need 'NOPWMPIN' to disable this.
To see what fuses are enabled, load the LST file, at the end, it has all the fuses that are set. Then the data sheet tells you what they 'do'. |
deenadayalan
Posted: Fri Aug 29, 2014 3:20 am |
| thank you sir |
deenadayalan
Posted: Fri Aug 29, 2014 5:40 am |
I got output sir, thank you for your valuable guidance. One more doubt sir, I used A1 for adc and connected B7,B6,B5 with leds. I got output in Proteus simulation but i didnt get output in real time. Led continued high state, also value=0. I am using pic18f4431 controller. Sir pls help me sir.
my coding
| Code: | void main()
float value=0;
//port_b_pullups (false);
set_tris_b(0x00);
set_tris_a(0xff);
output_b(0x00);
setup_adc (1);
setup_adc_ports( ALL_ANALOG );
setup_adc( ADC_CLOCK_INTERNAL );
while(true)
set_adc_channel(1);
delay_us(10);
value = read_adc();
if(value>0)
output_high(pin_b7);
output_low(pin_b7);
if(value>100)
output_high(pin_b6);
output_low(pin_b6);
if(value>200)
output_high(pin_b4);
output_low(pin_b4);
Posted: Fri Aug 29, 2014 10:40 pm |
This post shows a program for the 18F4431 which displays the ADC value
on a terminal program in Windows (example: TeraTerm):
http://www.ccsinfo.com/forum/viewtopic.php?t=40279&start=3
It's much better to use a terminal program for debugging, instead of LEDs.
You can see the results from the ADC. |
Posted: Fri Aug 29, 2014 11:49 pm |
Let's also point out that the value from the ADC, is an integer, not a float, and so the code as written has to convert this to a float, and then convert all the integer comparison values to floats, and do the much more complex comparison on these. Think again....
Proteus will work, even if the clock circuit is wrong. Have you actually checked the chip is running?. |
deenadayalan
Posted: Sat Aug 30, 2014 5:31 am |
| Dear Ttelmah sir i have pic16f877a development board,may i use for pic18f4431 controller at same 20mhz pls help me sir, |
deenadayalan
Posted: Wed Sep 03, 2014 11:50 pm |
| pls help me sir |
Posted: Thu Sep 04, 2014 1:09 am |
You want to know if you can run a 16F877A at 20 MHz on your Dev board ?
Yes, you can do it. |
