looking for the best way to measure freq DSPIC33EP512MU814
Posted: Tue Aug 26, 2014 4:42 pm
hi
i start a little project with DSPIC33EP512MU814.
and I'm looking for the best way to measure frequency
i tried to use the interrupt on setup_capture and count every rise edge
in one second.
and my results are not so good ...
the freq that i try to measure is between 0hz - 400hz
You would have to convert the method used in these threads
to use PCD-compatible functions. I can't easily do it because
I don't have the PCD compiler.
Mike Walne
Posted: Wed Aug 27, 2014 7:38 am
For low frequencies you are usually better off measuring the period of one (or several) cycles, then doing the maths.
I showed a method for PIC16-18s some time ago which worked well for high frequencies.
The process was very portable, maybe you could modify it.
