Code made in version 4.114 does not work in version 5.
sandrini
PostPosted: Tue Aug 26, 2014 4:54 am     Reply with quote
Dear Sirs,
I have a problem in my PCWHD compiler version 5.026. The below code compile without errors, but when I program my microcontroller, many messages are not showed in display.
This code was made in my older PCWHD compiler version 4.114 and when I compile with this version and program the microcontroller, the messages are all showed in display.
Please somebody would know inform what it is happening?
Thank you.
#include<18F4520.h>
#use delay (clock=8000000)
#fuses HS, NOWDT, PUT, BROWNOUT, NOLVP
#use RS232 (Baud=9600, xmit = PIN_C6, rcv = PIN_C7)
#include "LCD4B.c"
char msg_string_info1_por[]  = "   MENSAGEM 01  ";
char msg_string_info1_eng[]  = "   MENSAGEM 02  ";
char msg_string_info2[]      = "   MENSAGEM 03  ";
char msg_string_info3[]      = "   MENSAGEM 04  ";
char msg_string_info10_por[]  = "   MENSAGEM 06  ";
char msg_string_info20_por[]  = "   MENSAGEM 07  ";
..... //I have over 59 messages
lcd_ini();
printf(lcd_escreve,"\f %s\n", msg_string_info1_por);
printf(lcd_escreve,"\f %s\n", msg_string_info1_eng);
printf(lcd_escreve,"\f %s\n", msg_string_info2);
printf(lcd_escreve,"\f %s\n", msg_string_info3);
printf(lcd_escreve,"\f %s\n", msg_string_info10_por);
printf(lcd_escreve,"\f %s\n" ,msg_string_info20_por);
....  //I have over 59 messages (printf)
while (true);
PostPosted: Tue Aug 26, 2014 1:14 pm     Reply with quote
If you can post a test program that we can compile on our PC, then we
could look at your problem.
Try to make a test program with the smallest possible number of
messages, that shows the problem. Try to make us a test program
that has less than 59 messages, if possible.
sandrini
PostPosted: Tue Aug 26, 2014 1:51 pm     Reply with quote
Dear PCM programmer,
I made a program with 20 messages and again, in version 5.026, I have a problem... the messages does not appear in the LCD from the message 6.
But in version 4.114 all the messages are showed.
Thank you
#include<18F4520.h>
#include "LCD4B.c"
char msg_string_info10_por[]  = "  MENSAGEM 001  ";
char msg_string_info20_por[]  = "  MENSAGEM 002  ";
char msg_string_info30_por[]  = "  MENSAGEM 003  ";
char msg_string_info40_por[]  = "  MENSAGEM 004  ";
char msg_string_info50_por[]  = "  MENSAGEM 005  ";
char msg_string_info60_por[]  = "  MENSAGEM 006  ";
char msg_string_info70_por[]  = "  MENSAGEM 007  ";
char msg_string_info80_por[]  = "  MENSAGEM 008  ";
char msg_string_info90_por[]  = "  MENSAGEM 009  ";
char msg_string_info100_por[] = "  MENSAGEM 010  ";
char msg_string_info110_por[] = "  MENSAGEM 011  ";
char msg_string_info120_por[] = "  MENSAGEM 012  ";
char msg_string_info130_por[] = "  MENSAGEM 013  ";
char msg_string_info140_por[] = "  MENSAGEM 014  ";
char msg_string_info150_por[] = "  MENSAGEM 015  ";
char msg_string_info160_por[] = "  MENSAGEM 016  ";
char msg_string_info170_por[] = "  MENSAGEM 017  ";
char msg_string_info180_por[] = "  MENSAGEM 018  ";
char msg_string_info190_por[] = "  MENSAGEM 019  ";
char msg_string_info200_por[] = "  MENSAGEM 020  ";
lcd_ini();
printf(lcd_escreve,"\f%s", msg_string_info10_por);
printf(lcd_escreve,"\f%s", msg_string_info20_por);
printf(lcd_escreve,"\f%s",msg_string_info30_por);
printf(lcd_escreve,"\f%s" ,msg_string_info40_por);
printf(lcd_escreve,"\f%s" ,msg_string_info50_por);
printf(lcd_escreve,"\f%s" ,msg_string_info60_por);
printf(lcd_escreve,"\f%s" ,msg_string_info70_por);
printf(lcd_escreve,"\f%s" ,msg_string_info80_por);
printf(lcd_escreve,"\f%s" ,msg_string_info90_por);
printf(lcd_escreve,"\f%s" ,msg_string_info100_por);
printf(lcd_escreve,"\f%s" ,msg_string_info110_por);
printf(lcd_escreve,"\f%s" ,msg_string_info120_por);
printf(lcd_escreve,"\f%s" ,msg_string_info130_por);
printf(lcd_escreve,"\f%s" ,msg_string_info140_por);
printf(lcd_escreve,"\f%s" ,msg_string_info150_por);
printf(lcd_escreve,"\f%s" ,msg_string_info160_por);
printf(lcd_escreve,"\f%s" ,msg_string_info170_por);
printf(lcd_escreve,"\f%s" ,msg_string_info180_por);
printf(lcd_escreve,"\f%s" ,msg_string_info190_por);
printf(lcd_escreve,"\f%s" ,msg_string_info200_por);
while (true);
PostPosted: Tue Aug 26, 2014 2:09 pm     Reply with quote
I ran it in MPLAB simulator and I did get a problem. It only displayed the
first 5 messages. But, when I edited the message declarations so they
are declared as 'const', then it worked. It displayed all 20 messages.
Edit your file so all messsages are declared as 'const'. Example:
char const msg_string_info10_por[] = " MENSAGEM 001 ";
char const msg_string_info20_por[] = " MENSAGEM 002 ";
char const msg_string_info30_por[] = " MENSAGEM 003 ";
etc.
sandrini
PostPosted: Wed Aug 27, 2014 6:24 am     Reply with quote
Thank you PCM,
My program works now.
