gjs_rsdi
Interrupt flags clear in C |
Posted: Sun Feb 12, 2006 3:26 am |
Hi all
How can I clear interrupt flags in C
I check in the help and in 16F876A heade file and I do't find anything
on the subject.
I am new with C, working many years with PIC assembler.
Joseph Gross |
Posted: Sun Feb 12, 2006 3:31 am |
clear_interrupt(INT_XXX);
This was added about a year ago, but is not in the printed manual, or the version that comes as the 'help' file. I think it is in the latest downloadable .pdf.
Have a look at 'readme.txt', in your compiler's install directory. It contains details of many such changes, and is an essential 'addendum' to the manual.
vanderlei.vg
clear_interrupt |
Posted: Tue Aug 19, 2014 8:25 pm |
I tryed to "clear_interrupt(INT_TMR2)" inside the ISR but it seems doesnt work.
I have a PCM version 4.3.0.285
Fragment of the (ISR) program:
Code: | #INT_TIMER2 //Diretiva de identificação da interrupção do timer 0
void TIMER2 (void) //Função de tratamento da interrupção externa
output_low(BICO2);
clear_interrupt(int_timer2);
disable_Interrupts(INT_TIMER2);
I need to have the INT_TIMER2 cleared and disable when the ISR is finished.
As the clear doesnt works inside the ISR so I "clear" outside the ISR.
I want to know if it is possible to make a clear inside the ISR?
If yes, what is my mistake?
thanks,
Vandelei |
Posted: Tue Aug 19, 2014 8:46 pm |
The compiler automatically clears the interrupt with hidden code.
That's not the problem. To help us find the problem, please
answer the following questions:
1. What is your PIC ?
2. Post your setup_timer_2() function statement, showing all the parameters.
3. What is the oscillator frequency of your PIC ? Post your #use delay()
statement.
4. What is your compiler version. It's not 4.3.0.285. It's a 4-digit number
given at the top of the .LST file. The .LST file will be in your project
directory after a successful compilation. It will be a number such as
4.068, or 4.106, or 4.141, etc.
5. If possible, post a small, complete program that demonstrates the
problem. |
vanderlei.vg
Posted: Tue Aug 19, 2014 8:56 pm |
Ops!! CCS PCM C Compiler, Version 4.109, 53252 18-ago-14 18:08
Please take in account that this is my first program in C.
Code: | #include<16F1939.h>
#device ADC = 8 //Define 8 bits para o resultado da conversão AD
#use delay (clock = 8M)
#fuses HS, NOWDT, PUT, BROWNOUT, NOLVP, NOIESO, NOVCAP, NOFCMEN, NOCLKOUT, PLL_SW
#use fast_io(A)
#use fast_io(B)
#use fast_io(D)
int ad0; //Variável para armazenamento da conversão
short int PROXIMO=0;
/* ENTRADAS */
#define RPM_CLOCK PIN_B0
#define TINJ_POT PIN_A0
/* SAÍDAS */
#define BICO1 PIN_D0
#define BICO2 PIN_D1
#define BICO3 PIN_D2
#define BICO4 PIN_D3
#define IGN14 PIN_D4
#define IGN23 PIN_D5
#define RESULTADO_ADC PIN_D6
/* ......................................................... INTERRUPÇÕES */
#INT_EXT
void noventa_graus ()
PROXIMO=1;
//SET_ADC_CHANNEL(0); //Configura o canal de leitura 0
delay_us(300); //Tempo de ajuste do canal (necessário)
ad0 = READ_ADC(); //Faz a conversão AD e a salva na variável ad0
#INT_TIMER0 //Diretiva de identificação da interrupção do timer 0
void TIMER0 (void) //Função de tratamento da interrupção externa
output_low(BICO1);
clear_interrupt(int_timer0);
disable_Interrupts(INT_TIMER0);
#INT_TIMER1 //Diretiva de identificação da interrupção do Timer 1
void TIMER1 (void) //Função de tratamento da interrupção externa
disable_interrupts(INT_TIMER1); //Desabilita interrupção do Timer 1
output_low(IGN23);
output_low(IGN14);
clear_interrupt(INT_TIMER1);
set_timer1(61536); /*Retorna o valor inicial aos registradores TMR1H e TMR1L*/
#INT_TIMER2 //Diretiva de identificação da interrupção do timer 2
output_low(BICO2);
#INT_TIMER4 //Diretiva de identificação da interrupção do timer 4
void TIMER4 (void) //Função de tratamento da interrupção externa
output_low(BICO4);
clear_interrupt(int_timer4);
disable_Interrupts(INT_TIMER4);
#INT_TIMER6 //Diretiva de identificação da interrupção do timer 6
void TIMER6 (void) //Função de tratamento da interrupção externa
output_low(BICO3);
clear_interrupt(int_timer6);
disable_Interrupts(INT_TIMER6);
/* ......................................................... MAIN */
Set_Tris_A(0b00000001);
Set_Tris_B(0b00000001);
Set_tris_D(0b00000000);
output_D(0b00000000); //Coloca em 0 toda a porta D
SETUP_ADC_PORTS(sAN0); //Configura a entrada analógica AN0
/*Configura o a frequência do oscilador para o conversor A/D em fosc/8 (TAD = 1uS)*/
SETUP_ADC(ADC_CLOCK_DIV_8);
/* Configura o Timer 0 para contagem interna e prescaler de 1:256 */
SETUP_TIMER_0(RTCC_INTERNAL | RTCC_DIV_256);
set_timer0(20); //Inicializa o registrador TMR0 = 20 vai gerar cutoff
/* Configura o Timer 1 para contagem interna e prescaler de 1:1 */
SETUP_TIMER_1(T1_INTERNAL|T1_DIV_BY_1);
SET_TIMER1(61536); //Inicializa os registradores TMR1H e TMR1E
/* Configura o Timer 2 prescaler de 1:16 post 1:16 */
SETUP_TIMER_2(T2_DIV_BY_16, ad0, 16);
//SET_TIMER1(20); //
/* Configura o Timer 4 prescaler de 1:16 post 1:16 */
SETUP_TIMER_4(T4_DIV_BY_16, ad0, 16);
/* Configura o Timer 6 prescaler de 1:16 post 1:16 */
SETUP_TIMER_6(T6_DIV_BY_16, ad0, 16);
enable_interrupts(INT_EXT);
ext_int_edge(0,L_TO_H);
delay_ms(300);
PROXIMO=0;
/* Processo para sincronização com o sinal de RPM_CLOCK*/
while(!(PROXIMO)); //Fica aqui enquanto PROXIMO = 0
delay_us(30);
PROXIMO=0;
while(true)
/* 1º Pulso , giro 1 , 0-720 Graus (360 graus do giro 2) , BICO 1 */
if (ad0<25)
output_high(RESULTADO_ADC);
output_low(BICO1);
ad0=ad0-25;
ad0=253-ad0;
output_high(BICO1);
output_low(RESULTADO_ADC);
clear_interrupt(INT_TIMER0);
set_timer0(ad0);
enable_interrupts(INT_TIMER0); //Habilita interrupção do Timer 0
PROXIMO=0;
/* 2º Pulso , giro 1, 90 Graus, IGN-23 */
output_high(IGN23);
clear_interrupt(INT_TIMER2);
output_low(BICO2);
set_timer1(61536);
enable_interrupts(INT_TIMER1); //Habilita interrupção do Timer 1
PROXIMO=0;
/* 3º Pulso , giro 1, 180 Grau, BICO 3 */
if (ad0<25)
output_low(BICO3);
ad0=ad0-22;
output_high(BICO3);
clear_interrupt(INT_TIMER6);
enable_interrupts(INT_TIMER6); //Habilita interrupção do Timer 6
PROXIMO=0;
/* 4º Pulso , giro 1, 270 Graus, IGN-14 */
output_high(IGN14);
output_low(BICO1);
set_timer1(61536);
PROXIMO=0;
/* 5º Pulso , giro 2, 360 Graus (0 Grau) BICO 4 */
if (ad0<25)
output_low(BICO4);
ad0=ad0-22;
output_high(BICO4);
clear_interrupt(INT_TIMER4);
enable_interrupts(INT_TIMER4); //Habilita interrupção do Timer 4
PROXIMO=0;
/* 6º Pulso , giro 2, 450 Graus (90 Graus) IGN-23 */
output_high(IGN23);
output_low(BICO3);
set_timer1(61536);
PROXIMO=0;
/* 7º Pulso , giro 2, 540 Graus (180 Graus) BICO 2 */
if (ad0<25)
output_low(BICO2);
ad0=ad0-22;
output_high(BICO2);
enable_interrupts(INT_TIMER2); //Habilita interrupção do Timer 2
PROXIMO=0;
/* 8º Pulso , giro2, 630 Graus (270 Graus) IGN-14 */
output_high(IGN14);
output_low(BICO4);
set_timer1(61536);
PROXIMO=0;
Vanderlei |
vanderlei.vg
Posted: Tue Aug 19, 2014 9:38 pm |
More infos:
1) The signal on PIN_B0 is a squarewave, freq. 10 up to 450Hz
2) The outputs have leds.
Vanderlei |
vanderlei.vg
Posted: Sun Aug 24, 2014 9:17 am |
do you have any orientation about my doubts?
thanks |
Posted: Sun Aug 24, 2014 9:54 am |
The reason you are not getting any replies is:
We don't want to look at a program with 5 timer interrupts running at the
same time. We would not write a program that way.
Instead, we would have one timer interrupt, and then have a state
machine inside the interrupt code, and the state machine code would
produce all the pulses. |
