I Need to know my RB interrupt
sureshkumar
PostPosted: Wed Aug 20, 2014 8:28 am     Reply with quote
What is the problem in my code. Please help me.
#include <16F877A.h>
int set=0;
#INT_RB
void RB_SERV(){
   if(input(PIN_B7)){            //externally pulluped
      set=1;                      // variable for to avoid the delay function into this subroutine
void main(){
   enable_interrupts(INT_RB);
   while(TRUE){
      if(set==1){                  //This set variable act like the same thing. but in main function
         write_eeprom(0x00,4);
         delay_ms(5);              //Because the EEPROM writing is need some delay to next operation.
         write_eeprom(0x01,7);     // So this variable avoid this writing process into interrupt subroutine
         delay_ms(5);
         write_eeprom(0x02,9);
         delay_ms(5);
         write_eeprom(0x03,2);
         delay_ms(5);
         output_high(PIN_D2);
         output_low(PIN_D2);
         delay_ms(10);
         set=0;                    //After finishing the variable set to 0 for next and avoid again and again...
Pin B7 was to detect the power failure case. So this pin was connected with 7805 output with the help of a transistor.
Collector pin was connected with the PIN B7 pin.
Emitter pin was connected to ground.
Base pin was connected to 7805 output.
A large Capacitor(4700uf 25v) was connected with MCU's VDD and VSS for making delay. This delay time the writing process was running.
This method was working properly good in Proteus. But in hardware the interrupt was fired again and again... Even the pin state not change.
When I remove the Transistor Base pin that time the loop was contentiously running.
What is the problem in my code ?.
please help me.
Thanks and Regards
Sureshkumar.
PostPosted: Wed Aug 20, 2014 8:46 am     Reply with quote
On the 16F877, when you enable INT_RB interrupts, you enable them for
pins B4, B5, B6, and B7. But I suspect that you have pins B4, B5, B6
un-connected (floating input pins). This may cause continuous INT_RB
interrupts. To fix this problem, enable Port B pullups, wait a short time
for them to pull-up, then read PortB to clear the interrupt-on-change
condition latches, and then clear the INT_RB interrupt flag. See the
code below. After doing this, pins B4-B6 should not cause unwanted
INT_RB interrupts.
Add the code shown in bold below:
int8 temp;
port_b_pullups(TRUE);
delay_us(10);
temp = input_b();
clear_interrupt(INT_RB);
sureshkumar
PostPosted: Wed Aug 20, 2014 10:04 am     Reply with quote
INT_RB interrupts.
int8 temp;
delay_us(10);
temp = input_b();
Ok thanks a lot Sir, Yes I am leaving other pins without pullup and pulldown. Software pullup is enough ?.
But I need to execute at once for EEPROM writing purpose when the power is gone. I just add your code like this but the loop was continuously running even the pin is same state. If I need to make external pullup ?.
My requirement is when this pins go high that time only once write the data into eeprom. The capacitor will also goes discharged. Not issue. Even I think some mistake on my code sir.
My Question is Why this PIN_D2 always run even the B7 pin in same state ?.
What is the difference between if(input(PIN_B7)) and if ((!bit_test(last,7))&&(bit_test(current,7)))
#int_rb
void detect_rb_change() {
   int current;
   static int last=0;
   set_tris_b(0xF0);
   current=input_b();
   #if LOWTOHIGH
   if ((!bit_test(last,4))&&(bit_test(current,4))) {dbutton4=1;}
   if ((!bit_test(last,5))&&(bit_test(current,5))) {dbutton5=1;}
   if ((!bit_test(last,6))&&(bit_test(current,6))) {dbutton6=1;}
   if ((!bit_test(last,7))&&(bit_test(current,7))) {dbutton7=1;}
   #elif HIGHTOLOW
   if ((!bit_test(current,4))&&(bit_test(last,4))) {dbutton4=1;}
   if ((!bit_test(current,5))&&(bit_test(last,5))) {dbutton5=1;}
   if ((!bit_test(current,6))&&(bit_test(last,6))) {dbutton6=1;}
   if ((!bit_test(current,7))&&(bit_test(last,7))) {dbutton7=1;}
   #endif
   last=current;
int set=0;
#INT_RB
void RB_SERV(){
   if(!input(PIN_B7)){        //externally pulluped
   }                                // I think here is the problem if(!input(PIN_B7)) this is just like digital input.
                                   //So when the isr fired this state was executed.
                                  //so I the if(set==1) was in super loop,  that is why always run. I need this run at once.
void main(){
   int temp;
    delay_us(10);
    temp = input_b();
   while(TRUE){
         /*write_eeprom(0x00,4);
         write_eeprom(0x01,7);     // So this variable avoid this writing process into interrupt subroutinue
         delay_ms(5);
         delay_ms(5);
         delay_ms(5);*/
         output_low(PIN_D2);
#INT_RB
void RB_SERV(){
                                   //So the if(set==1) was in super loop,  that is why always run. I need this run at once.
Thanks and Regards
Sureshkumar.
