oxo
Structs within structs |
Posted: Thu Aug 14, 2014 7:37 am |
I have something like this ( I can't post the whole code because it's sensitive and v.big)
Code: | typedef struct calibration
float x0;
float y0;
float gain;
float offset;
typedef struct axis
float full_scale_range;
float scale_factor;
typedef struct
struct axis x;
struct axis y;
struct calibration calpts;
float range;
float K;
float x_raw;
float y_raw;
}sensor;
sensor elevation; |
and it compiles and works fine in the normal way, but when I use it as a bootloaded application, it fails at run time. Some of the values from the calibration struct read wrong.
I've searched for anything here on structs like this, but no luck.
Is this code acceptable in CCS?
PIC18F
compiler 5.026 |
Posted: Thu Aug 14, 2014 9:13 am |
Your syntax is slightly dubious.. You use, then don't use a typedef:
float x0;
float y0;
float gain;
float offset;
} calibration_t;
typedef struct axis
float scale_factor;
} axis_t;
typedef struct
axis_t x;
axis_t y;
calibration_t calpts;
float range;
float K;
float x_raw;
float y_raw;
} sensor_t;
sensor_t elevation;
You are declaring a typedef, which then expects a name, but don't give it a name, instead you give the structure a name, and omit the typedef name. So you then don't actually use the typedef.
Either do the typedefs as I show, or get rid of the typedef declaration, and just use the structure name. Note the use of _t, to show the typedef declarations (useful reminder...).
Now, using the typedef, without a name, might well cause the compiler to be doing something 'wrong', so might be your problem. It's _possible_ that this results in both typedefs having the same 'blank' name (low compiler trust mode....). Note how the structure name is optional, but the typedef name should be there (shown on the sensor_t declaration).
However in general, CCS is 'known' for sometimes having issues as types get more complex (generally though with things like arrays of structures inside a structure). However (that having been said), this is not overly complex, and appears to work perfectly in everything I try.
This should be acceptable.
How is the value actually used in the application?. Is it local, or a global?. const?. Realistically, if it works on a 'raw' compile, but not when built for use as a bootloaded application, then look at what is different when the code is bootloaded. Obviously less ROM. Interrupt re-vectoring. Where does the data come from?. EEPROM?. Are you sure the bootloader is working completely correctly? (something like some bytes being corrupted where a particular ROM page boundary is crossed, could cause unexpected errors). What happens if you build the code as normal, but use #ORG to force the actual routines to load in the same location as when you build for the bootloader?. Are you sure the bootloader isn't doing something like corrupting a ram area?. |
