mc@ey
Dspic30F4011 PLL Settings |
Posted: Mon Aug 11, 2014 1:36 am |
Hi All,
I am new in DsPic world. i often worked with pic18f family. In my Project i use dspic30f4011 with 10mhz quarz.
in my understanding i have a result from 2,5 MIPS
i would like to work with 4xPLL but i have no Idee, how can i set this in my source code.
i tryed with
#Fuses XT_PLL4
#use delay (Crystal= 10000000)
but it doesnt work.
Can somebody help me?
Thanks in advance.  |
Posted: Mon Aug 11, 2014 2:05 am |
Start by looking in the .h file for the chip, and at the data sheet.
You will see in the data sheet, that unlike the PIC18, with just *4 PLL, you have a choice of *4, *8, and *16. However then you see (table 21-1), that the PLL can only be used with the XT oscillator, EC clock input, or FRC internal oscillator. However on these chips 'XT' is rated for up to 10MHz.
A look at the fuses, finds XT_PLL4, XT_PLL8, & XT_PLL16,
So you can run at 40MHz, with the first, and clock=40MHz, or go to 80MHz, with XT_PLL8. The fastest you can run the chip, is with a 7.5MHz crystal, and PLL16, giving 120MHz master oscillator, and 30MIPS.
The delay has to be given the clock rate. So either:
#use delay (clock=40MHz)
or
#use delay (crystal=10MHz, clock=40MHz)
If you do the latter, you can get rid of the PLL fuse, since the compiler then 'knows' to use the *4 PLL. |
mc@ey
Posted: Mon Aug 11, 2014 4:00 am |
Ttelmah wrote: | Start by looking in the .h file for the chip, and at the data sheet.
or
Hi Thx for your answer..
I tried with / without
#Fuses XT_PLL4
and with
But it doesnt work.
How i need to change my settings. |
mc@ey
Posted: Mon Aug 11, 2014 4:07 am |
here is my Source Code;
#include <30F4011>
#Fuses NOWDT
#Fuses CKSFSM
#Fuses NOBROWNOUT
#device ICSP=1
#use delay( crystal=10MHz, clock=40MHz)
#use rs232(baud=38400,xmit=PIN_F3,rcv=PIN_F2) |
