pointer to ROM
gfbankston
pointer to ROM
PostPosted: Fri Jul 25, 2014 7:22 am     Reply with quote
THe following works in CodeVision and XC8 compiler, but not in CCS
const unsigned char Test_Msg[]={"Hello test"};
void flash2LCD(const unsigned char *);
flash2LCD(Test_Msg);
Of course, to print to my graphic LCD, I must do a lot. I have designed fonts as well and only send 8 bits at a time, and 'draw' the characters.
ROM pointer arithmetic is critical for this code.
I saw in the manual how to do a one time simple data access to a table, but how does one pass the pointer to a routine. The manual indicates you cannot, but other compilers do it (in PIC XC8 works fine).
TIA
GlenB
PostPosted: Fri Jul 25, 2014 7:41 am     Reply with quote
The quickest way to solve this one is to add the line shown in bold below:
#include <18F4520.h>
#device PASS_STRINGS=IN_RAM
#fuses INTRC_IO, BROWNOUT, PUT, NOWDT
#use delay(clock=4M)
void flash2LCD(unsigned char *msg)
printf(msg);
If you do that, it will compile and you will get this output in MPLAB simulator:
Hello test
