Joined: 03 Dec 2008 Posts: 184 Location: Gresham, OR USA
Read Output Pin Setting
Posted: Thu Jul 24, 2014 4:24 pm
Processor: 18F67K22
Compiler: 4.135
I'm using digital I/O to control a bunch of relays and I need to send out some diagnostics via serial port to show which output pins are set high.
How can I read the settings of my output pins, without affecting anything? I want to be sure the compiler doesn't change my outputs to an input when it does the read. It seems like such a simple thing but a forum and manual search doesn't doesn't yield the results I'm looking for. Perhaps I'm just tired...
