Problem Compiling for 16F1508 using V 5.016
Ray Frier
PostPosted: Wed Jul 23, 2014 11:45 am     Reply with quote
I'm trying to implement a DHT22 using the code from the Code Lib RHT03 Driver http://www.ccsinfo.com/forum/viewtopic.php?t=52077&highlight=dht22
I copied the source code and created a RHT03.c an put it in the driver lib.
When I compile it is Version 5.016 I get the following errors. Can someone help we understand what the problem is?
Am I doing someting wrong in the compiler?
*** Error 28 "C:\Program Files\PICC\devices\16F1508.h" Line 537(35,36): Expecting an identifier Bad SFR name
*** Error 12 "C:\Program Files\PICC\devices\16F1508.h" Line 538(2,5): Undefined identifier
*** Error 48 "C:\Program Files\PICC\devices\16F1508.h" Line 538(6,12): Expecting a (
*** Error 28 "C:\Program Files\PICC\devices\16F1508.h" Line 538(35,36): Expecting an identifier Bad SFR name
*** Error 48 "C:\Program Files\PICC\devices\16F1508.h" Line 538(35,36): Expecting a (
*** Error 28 "C:\Program Files\PICC\devices\16F1508.h" Line 539(35,36): Expecting an identifier Bad SFR name
*** Error 12 "C:\Program Files\PICC\devices\16F1508.h" Line 540(2,5): Undefined identifier
*** Error 48 "C:\Program Files\PICC\devices\16F1508.h" Line 540(6,12): Expecting a (
*** Error 28 "C:\Program Files\PICC\devices\16F1508.h" Line 540(35,36): Expecting an identifier Bad SFR name
*** Error 48 "C:\Program Files\PICC\devices\16F1508.h" Line 540(35,36): Expecting a (
*** Error 28 "C:\Program Files\PICC\devices\16F1508.h" Line 583(34,35): Expecting an identifier Bad SFR name
*** Error 110 "C:\Program Files\PICC\devices\16F1508.h" Line 584(5,6): Expecting a .
*** Error 43 "C:\Program Files\PICC\devices\16F1508.h" Line 584(13,14): Expecting a declaration
*** Error 28 "C:\Program Files\PICC\devices\16F1508.h" Line 584(34,35): Expecting an identifier Bad SFR name
*** Error 48 "C:\Program Files\PICC\devices\16F1508.h" Line 585(2,5): Expecting a (
*** Error 48 "C:\Program Files\PICC\devices\16F1508.h" Line 585(6,13): Expecting a (
*** Error 28 "C:\Program Files\PICC\devices\16F1508.h" Line 585(34,35): Expecting an identifier Bad SFR name
*** Error 48 "C:\Program Files\PICC\devices\16F1508.h" Line 586(2,5): Expecting a (
*** Error 48 "C:\Program Files\PICC\devices\16F1508.h" Line 586(6,13): Expecting a (
*** Error 28 "C:\Program Files\PICC\devices\16F1508.h" Line 586(34,35): Expecting an identifier Bad SFR name
*** Error 48 "C:\Program Files\PICC\devices\16F1508.h" Line 586(34,35): Expecting a (
21 Errors, 0 Warnings.
Build Failed.
Ray
PostPosted: Wed Jul 23, 2014 1:28 pm     Reply with quote
I didn't get that at all. It worked fine for me. Here is the compiler
output in MPLAB:
Executing: "C:\Program files\Picc\CCSC.exe" +FM "C:\Program Files\PICC\Projects\PCM_Test\PCM_Test.c" +DF +LY -T -A +M -Z +Y=9 +EA -EW
Memory usage: ROM=32% RAM=5% - 24%
0 Errors, 0 Warnings.
Build Successful.
Loaded C:\Program Files\PICC\Projects\PCM_Test\PCM_Test.cof.
BUILD SUCCEEDED: Wed Jul 23 12:20:58 2014
I did these steps:
1. I installed CCS vs. 5.016. I have the command line versions, so I
installed both PCM and PCH, even though only PCM is needed for this test.
2. I went to Program Files / PIC-C in the Windows Start button menu,
and I ran the Compiler Version program. I clicked on the "View Other
Versions" button, and then I double-clicked on the PCM and PCH boxes
for vs. 5.016 until they were set in bold. I then exited that window.
3. I went to the Code library link and copied and pasted his test program
into my "pcm_test.c" file that I have as a general purpose test project
in MPLAB.
4. I opened a new file in MPLAB, and I copied and pasted his RHT03.c
code into that new file. I then clicked "Save as" and saved it as RHT03.c
in the pcm_test project directory.
5. I then went to the MPLAB Configure menu and selected 16F1508 as
the PIC.
6. I pressed the "Build All" button in MPLAB and compiled it with no errors.
Ray Frier
PostPosted: Thu Jul 24, 2014 1:38 pm     Reply with quote
Thank you for the detailed response.
OK, that is very different than what I did, I used the CCS IDE (v 5.016). I created a source file and copied the code from the post in the Code Lib. I also copied the code for the RHT03.C driver and placed it in the PICC Drivers. And ran the compile.
I'll follow what you have outlined and give that a try next.
Thanks, Ray
