Having trouble with Signed and Unsigned INT type conversions
Tom-H-PIC
PostPosted: Tue Oct 28, 2003 2:01 pm     Reply with quote
This is what I have that works correct.
Int Nset;
Float Nor_f
Nset = 10;
Nor_f = Nset/.0001174;
Nor_f now = 85178.875
This is all fine and what I expected!
But I need to change Nset to a sign int so that if I decrement Nset I can test for <= zero.
Signed Int Nset;
Float Nor_f
Nset = 10;
Nor_f now = 5.1265171797906E-32
There must be some thing about type conversions / promotions that I don’t understand.
If I type cast Nset in to a float then it works just fine.
But I though with the constant being a float that the complier would promote Nset to a float automatically?
Signed Int Nset;
Float Nor_f
Nset = 10;
Nor_f = (float)Nset/.0001174;
Can someone give me insight me on this?
Thank All
PostPosted: Tue Oct 28, 2003 4:14 pm     Reply with quote
The rule with CCS is, if it doesn't work, then type cast it.
(ie., Do whatever you have to do, to make it work).
Birdie
PostPosted: Wed Nov 12, 2003 5:41 pm     Reply with quote
I agree with PCM Programmer whole-heartedly!
