Diego López
CCS + MplabX |
Posted: Wed Jul 16, 2014 3:36 pm |
Hola amigos, necesito su ayuda
Ustedes saben porque MPLAB X no reconoce los comandos de CCS ?
Yo ya instale el "Pluggin"
Muchas gracias
______________________________________________________________
Hello friends, I need your help
You know because MPLAB X does not recognize commands CCS?
I have already install the "Pluggin"
thank you very much |
Posted: Wed Jul 16, 2014 4:10 pm |
Do you mean the wavy underlines that MPLAB-X places below CCS
functions ? That was discussed in this thread (which you participated in):
http://www.ccsinfo.com/forum/viewtopic.php?t=49705
If you bought the CCS compiler, you could contact CCS support and
ask for the bif.h file. See the end of this thread:
http://www.ccsinfo.com/forum/viewtopic.php?p=164295
What is your CCS compiler version ? I ask that because I noticed that
modern (vs. 5.026) header files have the _bif function prototypes in
the header file. I suspect you have version 4.xxx of the compiler.
If you need some other way to make a function prototype header file,
you go here, and highlight all the functions with your mouse:
http://www.ccsinfo.com/content.php?page=syntax-functions
Then copy and paste them into a text editor, and edit them into
function prototypes. It can be done, it just takes time. |
Diego López
Posted: Wed Jul 16, 2014 8:16 pm |
Hola amigo, tienes razón yo había preguntado antes lo mismo, ahora quería saber si ya había una solución.
Gracias por la información
Hello Friend, you're right I had wondered the same thing before, and now wanted to know if there was a solution.
Thanks for the information |
