Problem with dsPIC30f4011 in complementary mode
JONNATHAN_R
PostPosted: Mon Jul 14, 2014 7:01 pm     Reply with quote
I am doing a position control system using complementary PWM mode, however I have had multiple problems to configure the additional module, the last configuration I have is this:
Configuration:
set_motor_unit(pwm,unit,options, active_deadtime, inactive_deadtime);
set_motor_unit(1,1,MPWM_ENABLE,0,0); //
setup_motor_pwm(pwm,options, timebase);
setup_motor_pwm(1,MPWM_FREE_RUN,999);
set_motor_pmw_duty(pwm,group,time);
set_motor_pwm_duty(1,1,q);
q = cycle is useful here is where I should define whether or PWM1 PWM2 mode is activated complementary.
The compiler does not throw me any error. The code is extensive but the only part that fails is the complementary PWM mode. I've been working on this week,
I appreciate your help...
Mad Mad
PostPosted: Tue Jul 15, 2014 8:25 am     Reply with quote
What compiler version?.
You talk about 'q' affecting the complementary mode, in your posted bits. It doesn't.
Complementary mode is selected in the set_motor_unit command, and is the default. The pin pair is then activated by the set_motor_unit command.
As a comment, you ought to think again about having the dead time as zero. Unless the switch 'off' time of each half circuit is guaranteed to be faster than the switch 'on' time, you need some deadtime.
Further comment, the duty cycle numbers are 2* the timebase numbers (CPU clock versus instruction clock). This is why the timebase register is 15bit, and the period register 16bit.
You are using the simplified (3 variable) version of setup_motor_pwm. I'd always explicitly set the prescaler, otherwise it may not give what you expect.
However I suspect the one that is causing your problems, may be OVDCON.
Add a word define to access this:
#word OVDCON=getenv("SFR:OVDCON")
and make sure you have the bits set to use the PWM.
OVDCON=0x300; //For your two bits - should be the default.
Some older compiler versions did not set this correctly.
Make sure you have programmed the polarity you want for the bits and how you want them to start set, in the fuses.
Get the manual 70062E from the MicroChip site.
JONNATHAN_R
PostPosted: Tue Jul 15, 2014 9:41 am     Reply with quote
Dear thanks for your answer,
I am using ccs xc16, I have done the following:
Postcaler leave 4 prescaler and, add 200 ns timeout according to calculations using crystal 20 MHz.
I have read the Manual 70062E.
Do not know about
I can not load records directly xc16.
Appreciate your help, and then the new configuration.
setup_motor_pwm(1,MPWM_FREE_RUN,4,4,999);
set_motor_unit(1,1,MPWM_ENABLE,200,200);
set_motor_pwm_duty(1,0,q);
where q = the useful cycle, I have not had much luck.
Thanks.
PostPosted: Tue Jul 15, 2014 6:23 pm     Reply with quote
CCS is NOT xc16!. This is not the xc16 forum.
You need to got to the microchip xc16 forum.
http://www.microchip.com/forums/f250.aspx
JONNATHAN_R
PostPosted: Tue Jul 15, 2014 6:29 pm     Reply with quote
greeting
You're right I can not program in CCS xc16, I am using MPLABXC16, to which I refer is that I take as a guide the CCS manual programming.
Thank you
PostPosted: Wed Jul 16, 2014 7:37 am     Reply with quote
Microchip XC16, is not CCS C. All the commands are different, which is why they won't work for you...
