Is it possible to burn/program/debug dspic33 with ICD2 ?
I use it for last 5 years at least and there was some topic where someone claims it's possible. Didn't check device support list but i was planning on using it with mplabx on linux.
Posted: Thu Jul 10, 2014 3:11 am
Depends on the chip.
There should be a 'readme for ICD2' in the MPLAB installation, This lists the supported devices.
Some chips do get complex. Some parts that can run at 3.3v, cannot program at this voltage (thankfully not many). This is a 'read the data sheet' problem.
