Now this is not working. Neither the debugger increments the timer, neither it works on a controller. I tried with timers 2 and 3 - no change.
On simulation in MPLab X it's working, but when I load the program to a controller - nothing.
What am I doing wrong?!
Thanks!
stoyanoff
Posted: Wed Jul 09, 2014 5:52 am
It seems the defined parameter
#define T1_INTERNAL 0x07
is not correct. I loaded manually T1CON register and everything works fine now. In my case the correct value was 69, but it depends on the situation.
I suppose the developer of CCS can fix this bug. I'm not sure how to open a ticket.
Best regards!
