haxan7
Can mikroICD interfere with CCS Bootloader? |
Posted: Sat Jun 28, 2014 8:10 am |
I have been trying to install CCS bootloader for 2 days without any success.
Does anybody know for sure if mikroICD interferes with CCS Bootloader?
I have easypic board, and I can't easily detach the programmer. |
Posted: Sat Jun 28, 2014 8:39 am |
The onboard programmer causes me no problems.
I am using the EasyPIC 7 with the ICDU-64.
Also, SIOW works with no problems. _________________ Google and Forum Search are some of your best tools!!!! |
haxan7
Posted: Sat Jun 28, 2014 9:06 am |
dyeatman wrote: | Also, SIOW works with no problems. |
Could you please tell me your compiler version and the PIC that runs the bootloader.
Thanks |
Posted: Sat Jun 28, 2014 2:20 pm |
5.026 and PIC18F45K22 _________________ Google and Forum Search are some of your best tools!!!! |
haxan7
Posted: Sat Jun 28, 2014 2:25 pm |
dyeatman wrote: | 5.026 and PIC18F45K22 |
Is it the same code in the example or did you modify it in any way.
I have been trying on my PIC18F45K22 and v5.008 without any luck.
Can't figure out what's wrong.
Do you mind sharing the code? |
Posted: Sun Jun 29, 2014 12:11 pm |
5.008 was still very early in the release candidate pool.
i would UPDATE as suggested and try again.
ie: the advice you got already is sound. |
Posted: Sun Jun 29, 2014 1:28 pm |
I am using the example files supplied with PICC with one single
modification. I changed the 16MHZ oscillator to 8MHZ in each file then
compiled ex_bootloader.c and programmed it into the 45K22.
I then compiled the second (ex_bootload.c) file. After I confirmed the
45K22 came up with the "Waiting for Download" prompt I used the SIOW to
download the compiled ex_bootload.hex file to the 45K22 and it worked first
time.
I noticed both files have 2014 copyrights on them indicating they were
changed this year.
Unfortunately you will have to ask CCS for an updated copy. It is a
violation of the CCS copyright for me to provide it. Being a registered
CCS user I feel sure they will send it to you. _________________ Google and Forum Search are some of your best tools!!!! |
haxan7
Posted: Sun Jun 29, 2014 1:32 pm |
dyeatman wrote: | I am using the example files supplied with PICC with one single
time.
changed this year.
CCS user I feel sure they will send it to you. |
Thanks for the reply.
I have figured out that the problem was with the flow control. Enabling the transmission delay to 2ms/char in Tera Term fixes the problem. |
