Internal Op-Amp Not Working [Solved]
mictel
PostPosted: Fri Jun 27, 2014 8:26 pm     Reply with quote
I'm trying to use the internal Op-Amps in the 16F1789 for the first time. I configured them as follows:
   setup_opamp1(OPAMP_ENABLED);
   setup_opamp1(OPAMP_HIGH_GBWP_MODE);
   setup_opamp1(OPAMP_I_TO_OUTPUT);
I have the Op-Amp configured as a voltage follower (inverting input connected to the output and applying the signal to the non-inverting input) but the Op-Amp is not reproducing the signal applied to the non-inverting input at its output. The input signal applied is a 0 to 5V saw tooth wave (2.5V offset) at 1kHz; the output remains at ground; with a slight ripple.
Additional configuration information:
I am addressing I/O ports as memory using the #byte directive with variable names using fast_io
#use fast_io(a)            // Fast IO for port a
This requires you set the port direction register using the Tris command:
  set_tris_a(0b00110010);
The pins associated with the Op-Amp are specified as inputs (1) and not assigned to any variable with the #Byte command:
#byte lat_a = getenv("SFR:LATA")
// port a #defines
#bit Spare1 = lat_a.0        // Spare Pin Assigned as output for debugging
// a1                                   OpAmp1 Output; Vr
#bit Disp1 = lat_a.2         // Display LED 1 output; Active Low
#bit Spare2 = lat_a.3        // Spare Pin Assigned as output for debugging
// a4                                   OpAmp1 + input; Vcap
// a5                                   OpAmp1 - input; Vr
#bit Disp5 = lat_a.6         // Display LED 5 output; Active Low
#bit Disp4 = lat_a.7         // Display LED 4 output; Active Low
Perhaps using fast I/O with an Op-Amp configuration is the problem. Would appreciate help to figure out why the Op-Amps are not working properly from those with experience working with the internal Op-Amps.
Thanks.
mictel
Problem Solved
PostPosted: Fri Jun 27, 2014 10:20 pm     Reply with quote
After some experimentation and quality time with the data sheet...
The format of Op-Amp setup is:
setup_opamp1(OPAMP_ENABLED|OPAMP_HIGH_GBWP_MODE);
Note that the option to connect the inverting input to the op-amp output (OPAMP_I_TO_OUTPUT) is in the 16F1789.h header file but no such option exists on the data sheet, subsequently, it does not work. A physical connection must be made between the inverting input pin and the output pin to create a voltage follower.
