why doesnt stop RA or RB interrupt
respected
PostPosted: Fri Jun 27, 2014 12:47 pm     Reply with quote
#include <18F14K50.h>
#fuses INTRC_IO,NOMCLR,NOWDT,NOBROWNOUT,NOLVP
#use delay(internal=8000000)
#INT_RA
void  RB_isr(void)
output_high(PIN_C3);
disable_interrupts(INT_RA5);
   enable_interrupts(INT_RA5);
   clear_interrupt(INT_RA5);
         output_low(PIN_C3);
This is my code.
In fact interrupt works but it always works. when I make to change pin A5, Pin C3 is being high state but again when i make to change pin A5 , pin C3 doesn't change low state.
I use 4.024 vers. Thanks
haxan7
PostPosted: Fri Jun 27, 2014 1:19 pm     Reply with quote
You have to read the pin that caused the interrupt to reset the interrupt flag.
(call clear_interrupt(INT_RA5); at the end of ISR)
Otherwise program will reenter the ISR.
Also you are disabling the interrupts in the ISR, I don't think you mean to do that.
Remove this line
Also try increasing the delay, delay is too low to be noticeable.
PostPosted: Fri Jun 27, 2014 1:21 pm     Reply with quote
With any interrupt, _you_ have to deal with the physical 'event' that triggers it.
So for the serial receive interrupt (for example), you have to read the received character, or the interrupt will keep triggering for ever (after all the character is still there wanting to be read...). For the 'interrupt on change' interrupts, you _must_ read the port that has changed in the handler. This resets the latch holding the 'copy' used to detect the change.
A search here will find dozens of posts explaining this.
respected
PostPosted: Fri Jun 27, 2014 1:31 pm     Reply with quote
"you _must_ read the port that has changed in the handler"
you are right. how i forget it. Thanks
  int a;
#INT_RA
void  RB_isr(void)
a=input_state(pin_A5);
         delay_ms(5000);
         output_low(PIN_C3);
