Bootloader in linux
Grkan13
Bootloader in linux
PostPosted: Mon Jun 16, 2014 3:28 pm     Reply with quote
I'm trying to program the PIC18f46k22 on linux via rs232.
I've used CCS C's ex_bootloader example. I can manage to update the firmware inside of the pic on windows by Tera Term.
But when I tried to do that on Linux with minicom, I can send the hex file but it doesn't change the firmware inside. Normally on Tera Term, after sending the file, it resets the pic and you can see the firmware is installed. But on minicom it does not reset the pic and when I try to reset it manually, I can see that it deleted the old firmware.
Can you please help me about this?
My compiler version is 5.021
And the firmware that I'm trying to send is :
#include <18F46K22.h>
#fuses NOWDT
#fuses nomclr
#use delay(internal=16MHz)
#include <bootloader.h>
   printf("\r\nApplication Version 1.0\r\n");
      output_toggle(pin_d1);
gpsmikey
PostPosted: Mon Jun 16, 2014 11:18 pm     Reply with quote
I have not worked with that, but one thing that may be getting you is the difference between the windows/dos world and Linux as what constitutes a new line (on one side it is CR/LF, on the other , CR if I remember correctly).
See this link for more info: http://en.wikipedia.org/wiki/Unix2dos
mikey
mikey
LiLou
PostPosted: Wed Jun 18, 2014 12:09 am     Reply with quote
What does Tera Term? Emulates the PIC?
